Using gen while driving
Submitted: Friday, Jan 02, 2009 at 20:48
Member - Damien L (QLD)
Question??
Can I use my e10 to charge second battery while driving? Some times I may stay in one place for a while and run it down a bit.
Will charging my second batt effect the alternator charge?
Reply By: Sir Kev & Darkie - Friday, Jan 02, 2009 at 20:58
What is wrong with just letting the alternator charge the battery when in transit and then if needed top the 2nd battery up with the generator when you reach
camp??
Cheers Kev
| Russell Coight:
342313
Reply By: Member - Doug T (NT) - Friday, Jan 02, 2009 at 21:29
If the No 2 Battery is totally isolated from the vehicle's charging system (ie as being attached to or in a Caravan) I would say yes, BUT in my other brand Gennie it does state to run while stationary but probably wouldn't hurt it if it was sealed road ,
342325
Reply By: JR - Saturday, Jan 03, 2009 at 09:54
E10 can only charge at around 3 or 4 Amps direct DC, or if you use a AC charger maybe 7Amps
Your car altenator can easily run up to 50Amps BUT only if charging batteries independantly, otherwise will charge to suit the "fullest" battery which can be very slow but still likely to be
well above 7 Amps
Just charge from the car
JR
342389
Reply By: Member - Damien L (QLD) - Saturday, Jan 03, 2009 at 10:59
Thanks fellas for the info. I will let the alternator do the job.
342397
