Sunday, Aug 10, 2003 at 07:06
hi, exhaust usually doesn't need modifying but you certainly need to upgrade your
suspension.the majority , if not all 4wds that come on to the market are not suitable for any resonable 4wding, as there usually isn;t enough ground clearance.
some good brands are, koni, old man emu and tjm make some good ones as
also the tyres that come on a standard 4wd are usually road only tyres. you'll need to get some all terain tyres which allow you to comfortably travel off road without to many dramas.
another good investment is a
snorkel, which don't set you back to much and can certainly help you in deep or even shallow water crossings.the
snorkel is almost a necesity for diesel 4wds if you want to go in water. it raises the air intake level and allows resonable water crossings,as water in the engine isn't real good at all.if you own a diesel it's lights out for good.-new engine required.
another handy yet cheap accessory is a cb radio. don't quote me but 99% of 4wders will have a uhf cb radio in their car. as communicating with other drivers is very essential in many situations. ie convoys,recovery situations and
hill crossings to name a few.
also a major upgrade i would undertake would be to fit some secondary lights , ie
driving lights or spot lights.out in the bush while , not highly recomended, night driving is sometimes the only option, and the further down the road you can see the better. cows, sheep, foxes roos and so
forth can do substantial damage to your car.
the fuel situation is a tough question, as most destinations, not to far off the beaten track have service stations moderately positioned for refueuling.however if your car is an unleaded version some stations don't always have fuel and a long range tank might be the go.if you are going to keep the car for a while and do lots of long 4wding. i would recomend another tank.
also before you go offroad. you MUST purchase your own recovery gear, as borrowing whilst handy is not the practical thing to do.you'll need minimum a snatch strap, 2 or three bow shackles , shovel and a piece of wood or metal to act as a base for your jack on soft or uneven ground. this will stop your jack sinking in sand and mud.the shovel will eventually get you out, if you keep digging and further down the track you can get a winch to pull you out on your own.
this was just my opinion and as you said $$$$ wasn't an issue so i hope you can takesomething from it.
cheers and see you off road.
27316
