Tuesday, Dec 09, 2008 at 09:20
What is the braked capacity of your vehicle If u want a heavier trailer get on with brakes on it Problem solved probably
The explanation I had was that basically if your trailer or vans Plated ATM is less than your vehicles capacity you can load it up fully and be legal.
If it exceeds it the temptation is to still fill it up and then be illegal.
You do what you like but if its too heavy and you have a prang GOODBYE INSURANCE.
The Caravan repairer I go to says he has at least 3 calls a week from insurance companies on this subject.
If you doubt the advice ring up the RTA and ask them.
Im only going on the advice from an engineer within the industry who makes a living by certfying these vehicles so presumably he does know the rules.
In saying the above there are heaps of illegal rigs on the road.
I saw a van the other day that was not only obviously too heavy for the tow car but had chequer plate tool boxes along both sides of the chassis.
I would hate to think what it actually weighed and how far over its rated ATM it was.
Manufacturers in general are not over generous in putting heavier than necessary running gear so if its overloaded it can run bearings, blow tyres and do other nasty things usually in the middle of nowhere.
606431
