Leaking Tent Floor
Submitted: Thursday, Oct 09, 2008 at 07:43
Treading Lightly
Just returned from 3 great days spent
camping at
Dingo Tops, near
Gloucester. Unfortunately it rained on Sat night, thought everything would be safe in the tent, but
water came in via the seam in the floor. The tent is a
Southern Cross Tourer (one centre pole) the floor is a vinyl type material with one centre seam.
The
water has run off the tent walls onto the poly vinyl base that the tent was on, and was trapped between the tent floor and the base, and then seeped into our bedding.
Any ideas as to how I can seal the seam.
JD
Reply By: Peter 2 - Thursday, Oct 09, 2008 at 07:51
We had the same problem years ago, I carefully waxed the actual thread on the seam and then stuck a strip of heavy duct tape over the seam on the underside of the tent.
Never leaked again and have only replaced the tape twice in 20 odd years.
When putting the tape on be careful to have the floor flat and even, clean and dry and don't stretch the tape as you apply it.
Pay attention to getting the ends sealed, either up under a lip where it joins the canvas or if it is a tent with the join exposed then a smear of silicon to seal the end.
329014
Reply By: Treading Lightly - Thursday, Oct 09, 2008 at 08:16
Hi Peter,
Thanks for reply and info. What type of wax did you use.
JD
329018
Follow Up By: Peter 2 - Thursday, Oct 09, 2008 at 11:39
I just used one of those waterproofing wax sticks sold in the
camping stores.
We also use the shadecloth these days which works
well, double thickness and about an extra metre out the front of the tent to stand on and put shoes on.
596349
Reply By: madcow - Thursday, Oct 09, 2008 at 08:23
Have you given any though to putting shadecloth under your tent?. It would allow
water to run through but still stop grass,leaves etc from sticking to your floor. I guess most of us have been caught using a tarp or plastic to protect the floor area and only whne it rains the obvious becomes evident. I use Liddys waterproofing and have found it to be excellent on our
Southern Cross Camper
329019
Follow Up By: Treading Lightly - Thursday, Oct 09, 2008 at 09:27
Thanks for reply,
Thanks for info on shadecloth it seems like it would solve the problem. We are heading down to the High Country in Jan and will get some before the trip. What is Liddys??
JD
596331
Reply By: guzzi - Thursday, Oct 09, 2008 at 18:41
BCF and a few other
camping stores have McNett tent floor sealant and seam sealant.
Have a look here;
http://www.mcnett.com/
look under tents.
The seam sealant is a clear polyureathane paste that stays flexible after it dries.
Ive used both products on my 12 yr old Salewa hiking tent, it seems to have cured the Titanic syndrome it had the last time it rained (
water coming in everywhere).
329097
Reply By: howie - Thursday, Oct 09, 2008 at 20:17
good luck with sealing the seam.
personally i always use a tarp under the tent, but do not leave any part of the tarp sticking out to prevent pooling between the tarp and tent floor.
might end up with a few inches of dirty floor around the edge, but better than seeping in.
329119
Reply By: Ballfyboy - Thursday, Oct 09, 2008 at 23:36
Most reputable
camping shops should stock Sevylor Seamseal. Hiking shops will more than likely also stock aquaseal. The seamseal is an awesome product and lots of hikers/mountaineers will keep it in their
first aid kits. It will stop anything getting through. If your tent rips in strong winds or something like that, just sow it up with dental floss and cover it with the seamseal and it will last for years. Use it on your boots if your rand starts to peel off.
Shade cloth is good, however just make sure you fold the tarp back under the fly and you should be ok.
Good luck.
329164
Follow Up By: Treading Lightly - Friday, Oct 10, 2008 at 07:14
Thanks guys for all info, I am off to BCF today.
JD
596477
