Can you freeze vacuum packed meat?
Submitted: Friday, Sep 26, 2008 at 11:49
Louie the fly (SA)
I got some meat vac packed this morning and I forgot to ask the butcher if it can be frozen in the packs. I assume it can, but I'm not sure.
Anyone??
Reply By: Steve63 - Friday, Sep 26, 2008 at 11:59
Yes it freezes
well. We usually freeze ours as it avoids some issues if you wear through the plastic.
Steve
327251
Follow Up By: Louie the fly (SA) - Friday, Sep 26, 2008 at 12:02
Thanks Steve. Suppose it helps the fridge stay cool as
594428
Follow Up By: Steve63 - Friday, Sep 26, 2008 at 12:23
Yes we run the fridge on quite a low setting and let it thaw over a few weeks. I would not let it warm up to much though. I have been told this is not really a problem and just shortens the life of the meat. But I'm not game enough to try it. The theory is that if there is not much oxygen and it is cool then there is little oppertunity for bacteria to breed. If it gets warm then bacteria still can not breed. However some bacteria do not require oxygen to breed. Some of these are very bad, C. botulinum is one in point. Rare but severe food poisoning resulting in paralysis and without ventilator support likely death. I don't have a ventolator in the
first aid kit so I don't let things get to warm.
Steve
594432
Reply By: Member - Willie , Sydney. - Friday, Sep 26, 2008 at 13:00
Anyone??
I used to freeze my cryovac meat packs and last time I was at the butcher I ordered them and asked him to freeze it for pick-up. He said that was a mistake, as the plastic bags get brittle and damage easily. I have frozen them in the past though without problems.
Having said that though, I don't freeze them any more because they last for 6 weeks in the normal fridge ( they did on my last WA trip anyway) . Why bother to freeze them and waste
battery power, if they last that long in the normal part of the fridge.
Willie.
327257
Follow Up By: Willem - Friday, Sep 26, 2008 at 14:06
Waste
battery power???....hahahahahahahahaha
Ahhh..... yer funny, Sir Willie..............
When my Dad was getting on in years he got a similar notion in his head and used to drive at night with lights on low beam to save the battery, much to our concern....lol
594441
Follow Up By: Member - Willie , Sydney. - Friday, Sep 26, 2008 at 16:48
Yes , in Korea I always used to be amused that at night when the cars stopped at a red light , they all switched off their
driving lights till the light went green - weird . I once asked if it was to save wear and tear on the bulbs , the battery or ?? , but never really got to the bottom of it .
Willie .
594469
Reply By: Member - Doug T (NT) - Friday, Sep 26, 2008 at 13:11
Louie
If your going to freeze it then why vac pack it, just stick it in normal freezer bags, I got mince here thats 2 months old, tastes good too.
327259
Reply By: Member - Davoe (Yalgoo) - Friday, Sep 26, 2008 at 13:14
yes and it will last forever if frozen as the superior vac packing doesnt allow freezer burn or dryness
327260
Reply By: PradoTrev - Friday, Sep 26, 2008 at 13:19
As an ex butcher my advise is such
freeze it no problems with the product but bear in mind the seal on the vacuam poch will be comprimised and should be thawed and used. Once thawed the bag will contain the fluid which will acelerate the souring process and the fluid will be the first to turn. (mosture and bacteria thing now that the bag will allow air in to it.
Freezing it (in the vac pouch) will reduce freezer burn if long term in the freezer.
If you are traveling for weeks I would suggest packing the vacum packed meat in a plastic container to help protect it from being pearced by a can or other more solid item. avoid packing some frozen and some not because you will find that the frozen once thawed will need to be used before the non frozen for above reasons therefore defeating why you would freeze the meat in the first palce.
also thecontainer will help contain leakage from any seals that may be breached in transit avoiding needing to clean the fridge
TM2CW
trevor
327262
Follow Up By: Louie the fly (SA) - Friday, Sep 26, 2008 at 17:04
Thanks Trev. Straight from the horse's mouth, so to speak. Have decided not to freeze it.
594471
Follow Up By: Member - GREENDOG - Saturday, Sep 27, 2008 at 20:55
Ex Butcher,What meat can't i vacum seal
594653
Follow Up By: PradoTrev - Sunday, Sep 28, 2008 at 12:27
All meat can be vacum sealed.
You will get great results with marinated meat as this helps draw the flavour in.
Crumbed products come out the worst, having said that if you interlace cling / glad wrap between each piece you will get a much better outcome when you open the pack (long term crumbs might sour thats all)
The smaller you pack the better I always pack in 2's or 3's that way they fit better and if a seal goes you lose less product.
I should write a book on the do's and donts on food for
camping cos there is so much miss info out there.
594736
Reply By: On Patrol & TONI - Friday, Sep 26, 2008 at 20:26
Louie
We freeze the meat in resealable bags, as flat as possible, and avoiding meat with bones in it, this prevents the bone breaking the bag seal, place it all in the "bottom of the fridge" and layer it with newspaper or soft towel and cover with a towel, this stays frozen for weeks in the fridge and helps lessens the power usage, I think.
Cheers Colin.
327308
Reply By: Kiwi & "Grenade" - Friday, Sep 26, 2008 at 21:29
never needed to seeing that if they do a good job it will last for up to 6 weeks but have been told not to as it can expand or something and perforate the bag.....
why needing to freeze ?? If your going to freeze it why vac pack it???
327324
Follow Up By: Member - Davoe (Yalgoo) - Saturday, Sep 27, 2008 at 21:45
so it will last forever. For my mates 21st we had frozen cryovacce fillet steak that hadbeen frozen for 10 years
594676
Reply By: aka - Saturday, Sep 27, 2008 at 07:59
Went west for 3 months with an engel full of cryovac meat from local butcher ,ate the last of the meat in the last week of the trip . We are lucky here with a good butcher and good meat
327350
