Using a jaffle iron over a butane cooker
Submitted: Friday, Aug 22, 2008 at 12:27
ben_gv3
This is a very simple question, but has anyone used a double jaffle iron over a butane cooker?
The only reason I ask is, as oppossed to using a fire, the heat from a butane cooker is a lot more directional and lower then a fire.
Also, being cast iron, how long would it take to heat up to make a nice warm toastie?
Reply By: Michael ( Moss Vale NSW) - Friday, Aug 22, 2008 at 12:41
WE have a side by side jaffle iron and heating in the middle works fine but most jaffle irons are one in front of the other and have a bit of distance between them.. that could be a problem.. Michael
321713
Follow Up By: ben_gv3 - Friday, Aug 22, 2008 at 12:46
Thanks for the quick reply. How long does it take to
cook? Just worried about gas usage and how many spare gas cans I would need to bring along.
588566
Follow Up By: Michael ( Moss Vale NSW) - Friday, Aug 22, 2008 at 14:48
I dont know about gas usage but a double takes about 5 minutes at most. Michael
588591
Reply By: mannrivermudrwestler - Friday, Aug 22, 2008 at 12:52
Practice makes perfect, just get the thing out and wack up a meal, when your out there in the bush and your hungry do what i do eat it cast iron is good as it displaces heat rapidly over a large area aviod ''ding dongs from hong kong'' cast iron as they have high content of lead in them
321718
Follow Up By: mannrivermudrwestler - Friday, Aug 22, 2008 at 14:38
I forgot to mention that the better known brands for cast iron are usually better quality , and less likely to have lead in them and also to break as easy as "made in china''
588590
Follow Up By: ben_gv3 - Saturday, Aug 23, 2008 at 10:46
Aren't they all made in China?
Which brands are the best to look at? I guess the disposal store ones wouldn't be that good then? How about the Anaconda ones?
588729
Reply By: austastar - Friday, Aug 22, 2008 at 14:01
We use a couple of Aluminium Jaffle irons on a stove top.
Start off high heat and then cut it down.
Just use commonsense and your nose for cooking times.
Cheese /beans / juices can make a bit of a mess on the stove, where as a fire it doesn't matter a hoot.
321729
Reply By: Member - Michael O (NSW) - Friday, Aug 22, 2008 at 14:51
Our jaffle-o-matic works beautifully on our butane stove.
Just make sure you heat the iron up and get it hot before you add the bread. And remember, butter on the outside...
321735
Follow Up By: Member - Tom V (WA) - Friday, Aug 22, 2008 at 15:45
if u are looking after yr health, use baking paper insetad of butter.
cheers Tom
588602
Reply By: Member - Pesty (SA) - Friday, Aug 22, 2008 at 20:08
We use the very old alum ones, we find them the best, has taken many years to gather a collection, and we use them on the petrol stove and gas regularly.
They
cook great especially if you can get an old toaster grill under them to lift them up a bit off the flame.
Cheers Pesty
321775
