Securing Spare Wheel To Roof Rack
Submitted: Tuesday, Aug 12, 2008 at 22:55
Mike GU
Hi, I am interested in securing my 2nd spare to the roof rack, and was just after some ideas on how i would secure it there and be confident it wont go flying while off road. i know Tracklander sell a J bolt but i think these are just overpriced for the application.
Thanks in advance
Reply By: Member - Willie , Sydney. - Tuesday, Aug 12, 2008 at 23:05
Mike ,
I just put it hard up against the front rail and then secured it crossways with a wide hvy duty ratchet strap . I just did 12,000 km with it and it never moved .
Cheers ,
Willie .
320486
Reply By: Member - Mick O (VIC) - Tuesday, Aug 12, 2008 at 23:06
Mike,
J bolt is best way I've found. What is the base of your roofrack constructed of? If mesh, use two...in fact, use two anyway. Travelled many km in the Navara with a rhino rack and basket this way with no problems. Used a good quality ratchet strap as a redundancy measure.
Image Could Not Be Found
Cheers. Mick
320487
Reply By: Member - Glen O (WA) - Tuesday, Aug 12, 2008 at 23:38
I converted a ratchet strap into a 3 leg strap with two fixed legs and used the ratchet part on the third leg. Used a stainless ring in the middle to join the three legs. Got the local upholtress to stitch up the staps.
Glen.
320490
Reply By: Member - Bucky (VIC) - Wednesday, Aug 13, 2008 at 04:18
Mike
All I use, or have used, was a few bits of the good old Telstra rope. But I suppose any rope will do.
Go over, in thru and around, and the tyre is on the roof racks for good.
Bucky
320497
Reply By: Member - Phil B (WA) - Wednesday, Aug 13, 2008 at 07:25
Mike make your own J bolt.
Go to Bunnings etc get a bit of all thread at least 10 mm bend it into a J, cut it to length.
Fit a bit of hose over the bolt to stop thread cutting into your rack. Buy a nut, preferably a nylock, to suit your diameter of all thread and you have a neat and easy to use J bolt.
I have been using these for years without any problems.
320500
Follow Up By: Member - Duncs - Wednesday, Aug 13, 2008 at 13:46
If you weld a handle to
the nut it saves looking for a spanner. (As seen in Louie's pic below).
Better still, I had one years ago and I used a securing wheel off the top of a ball coupling. I could grab hold of it and give it a good spin so it came off easy. It was also big enough to get hold of and make real tight when screwing it down.
Duncs
587322
Reply By: On Patrol (Project TONI) - Wednesday, Aug 13, 2008 at 07:50
Mike GU
4WD megastores have a Heavy Duty 3 way tie down just made for that job, Vlad designed and had it made for the outback challenges and I have used
mine on many occasions, good stuff.
Colin.
320504
Reply By: Member - Serg (VIC) - Wednesday, Aug 13, 2008 at 09:26
I use to curry second one on the roof rack in the past. As other said – ratchet strap or rubberized rope will hold it absolutely secure. Problem what I have found however is centre of gravity moved up and that makes car to do more bodyroll that I like. Mind you it was leaf-in-all-corners 60, it is very stiff by nature. Now with full coil 80 I do not put anything heavy on the roof.
Serg
320511
Reply By: Kiwi & "Grenade" - Wednesday, Aug 13, 2008 at 10:30
Nath welded up some pole for the landcruiser that had a bolt on top of the wheel....dunno how else to describe it.....bit of metal, somehow attatched itself to the roofrack and somehow bolted on the wheel....held it real
well.....!
320520
Reply By: Ozboc - Wednesday, Aug 13, 2008 at 11:53
Another easy way would be to get 2 large plates ( steel plates ) and some threaded bar --- plate goes under your roof rack cage -- Then place in the center of the wheel and the threaded bar goes through the 2 plate and through one of the wheel stud holes -- nut at either end -- tighten as required ...
Boc
320524
Reply By: Louie the fly (SA) - Wednesday, Aug 13, 2008 at 12:50
How about this simple idea. Get a bit of 50x8 flat bar (or similar size), weld a piece of angle underneath and then drill a hole through the middle. Get some M12 allthread (zinc plated or stainless of course), heat the end and form a small hook, and secure it by hooking the hook under the wire base, slipping the plate over and tightening up with a nut handle.
320532
Reply By: Geoff43 - Wednesday, Aug 13, 2008 at 17:48
Make sure you put something between the rubber of the wheel and the steel of the roof rack,
mine rubbed through the outer (wall) layer of rubber and I wasn't game to use the wheel again.
Geoff43.
320582
Reply By: The Geriatric Gypsies - Wednesday, Aug 13, 2008 at 20:17
goodday guys
many ways of fixing to the rack but i always put a bit of chain thru with a padlock as ther are some dubious people around who would like an extra wheel for there trucks
steve
320607
Reply By: Richard Kovac - Wednesday, Aug 13, 2008 at 21:17
This is a hook to suit an ARB roof rack, after making it or buying it drill a small hole and fit a pad lock use two nut as a lock nut.
Richard
320626
