Regarding Small AA/AAA Penlight Type Batteries
Submitted: Wednesday, Jul 16, 2008 at 21:54
Geoff1967
I seem to use quite a few of these on things like headlights, torches etc. and they aren't cheap.
Do you use:
a) cheap batteries and buy in bulk.
b) dear Lithium type batteries (if so what brand is best/lasts longest)?
c) Rechargable batteries. This is what I'm starting to lean towards. If anyone has experience with rechargeables including good/bad brands and where you get them from (Kmart,
camping stores, Dick Smith, wherever) please let me know. Seems to me long-term rechargeables are the most economical.
Any feedback appreciated.
Reply By: TD100 - Wednesday, Jul 16, 2008 at 22:00
i use the NIMH AA and AAA from Jaycar and will never use normal batteries again.if i do i buy varta alkalines from the warehouse or go-lo (cheap and good batteries) Paul
315685
Reply By: Member - Darren & Janella (WA) - Wednesday, Jul 16, 2008 at 22:07
G'day Geoff1967,
I've been slowly replacing my aa/aaa with the varta brand of batteries. I use the Varta 15 min charger to recharge these batteries which will recharge the 15min varta rechargable batteries in 15mins (obviously). I've also started buying the varta accu charge batteries in 2100mah and 2500mah which can also be used in the same charger but take a little longer to recharge. You can use the charger off the mains and it can also be used off 12volt in the car (handy when travelling). You can buy these from Dick Smith/Tandy, K-Mart etc...). The 15min charger cost me about $80 (on special) a couple of years ago. Use the batteries in the handheld uhf, torches, cameras, clocks (around the house).
Darren
315688
Follow Up By: Geoff1967 - Wednesday, Jul 16, 2008 at 22:18
Sounds good.
How many recharges can you get before the batteries totally die and do rechargeables last as long as decent disposable batteries beofre you need to recharge them again?
581882
Follow Up By: Member - Darren & Janella (WA) - Wednesday, Jul 16, 2008 at 22:25
I think it's around 1000 recharges (but I could be wrong). I've had the 15mins ones since buying the charger. In regards to how long they last the 15 min rechargables we use in one of the clocks in the house seems to last around 3 months. The 2500mah one's we stuck in our canon digital camera 3 months ago are still on their first charge and the camera has been used at least 1 once a week.
581886
Reply By: Member - V8Diesel (WA) - Wednesday, Jul 16, 2008 at 22:34
I've standardised on AA rechargables for everthing with a 12V car charger.
I run my torches, GPS, cameras, hand held UHF's etc off them.
Best thing I ever did. Costs a bit to set up, but it's all free from then on and you always have plenty of batteries.
315690
Follow Up By: Geoff1967 - Wednesday, Jul 16, 2008 at 22:44
Ive got so many black 12V leads throughout my car I've started colour-coding them lol
581890
Reply By: Member - Mike DID - Wednesday, Jul 16, 2008 at 23:09
The ONLY AA or AAA batteries I'll be buying from now on are the Sanyo Eneloops.
If you want NiMH batteries to last, you must discharge and recharge them AT LEAST once every three months if you don't use them regularly.
315696
Follow Up By: Member -Signman - Thursday, Jul 17, 2008 at 08:57
'Morning Mike
How does one 'discharge' NiMH type batterys ???
581919
Follow Up By: Member - Graham H (QLD) - Thursday, Jul 17, 2008 at 10:48
One buys a charger/discharger from Jaycar part no MB-3512 for $69.95 and it does 10 at a time
581932
581933
Follow Up By: Member - Graham H (QLD) - Thursday, Jul 17, 2008 at 10:50
Sorry for the double post.
Bl**dy server errors
581934
Follow Up By: Member - Mike DID - Thursday, Jul 17, 2008 at 11:46
Each cell needs to be discharged to 1.0 volt per cell at least every 3 months, or it will lose ability to hold charge.
I have a Maha Powerex MH-C9000 which can charge and discharge up to 4 cells. It can use settable currents and do a preset number of cycles of discharge+charge to rejuvinate cells that have not been cycled.
581939
Reply By: aussiedingo - Thursday, Jul 17, 2008 at 04:39
G'day, I have used for a lot of years in my gps's, cb's, cameras, torches etc. Digitor NiMh batteries (
orange) from Dick Smith. After trying most brands these still outlast all others in usage rate & age. They come with a 12/240, 1 hour charger. The higher mAh the better, regards,
Dingo
315701
Reply By: Mainey (wa) - Thursday, Jul 17, 2008 at 05:34
Energizer rechargeable Ni-MH batteries, with Energizer charger which runs off 12v or 240v (via Inverter)
Takes 1 hour to recharge up to 4 batteries in a combination of either 'AA' (900mAH) or 'AAA' (2500mAH)
Mainey . . .
315702
Reply By: stevesub - Thursday, Jul 17, 2008 at 07:05
Note that the 10 or so rechargeable AAA batteries (Ni-MH) I have are all 1.2V, NOT 1.5V or thereabouts that the alkaline AAA batterys are.
This means that on some stuff that I have, they do not work or do not work very
well as the voltage is too low.
Rechargeable AA batteries, great and I use them all the time in the camera and GPS but do keep a good set of alkaline batteries with each device for when the rechargeable s go flat when out for the day. I hardly ever have to use them though.
Crazy Clarks have cheap Duracells which is usually hwat I buy for non-rechargeable.
Stevesub
315709
Reply By: Robin Miller - Thursday, Jul 17, 2008 at 07:56
Hi Geoff
Our emphasis tends to be on performance of the product and hence we shy away from rechargeable Ni-cad/Ni-mh cells.
The lower voltage of 1.2 instead 1.5 means that output from lights and radios is typically 1.2^2 / 1.2^5 or only around 2/3 rds
Also in general the total energy significantly is less from the rechargeables.
Got a stack of these now removed from products, as we also try to standardize on using AA's or AAA if no option.
Where real performance is required we use the energiser lithiums and while these are expensive they can usually be brought for 1/2 price. E.G. Both a local
supermarket and Bunnings have had them at 4 for $9.95 in a buy "2 get 2 free offer".
These are great and using a luxmeter I measured a 20% increase in light output from a torch with them over the normal non-rechargeable alkalines.
Their huge weight reduction is an advantage when used in a UHF handheld on say a bike helmet.
AS for non-rechargeable alkalines -
well first they can usually be topped up or re-charged a couple of times and I usuall refresh them before a trip, but if you overdo this they leak.
But Jaycar and other
places sell them in big 40 packs from time to time at 50c each so there not to bad in price anyway
315712
Reply By: baldman - Thursday, Jul 17, 2008 at 16:05
We use cheap batteries,
Our local $2
shop has Duracell parallel imports and sell them real cheap at times can get AAA and AA batteries for less than$1 each.
They last just as long as normal duracell with the only difference being that all the writing on the batteries and packaging is in chinese.
315762
Reply By: Member - Phil G (SA) - Thursday, Jul 17, 2008 at 16:27
Depends:
LED torches and headlights: I use alkalines because the torches sit around unused, and alkalines don't self-discharge. And you know when the batteries are getting flat because the light gradually dims. When you use NiMH, they self discharge and you find the torch works fine when you test it, and is dead a few minutes later (very flat discharge curve).
Normal torches: NiMH because they use a lot of power.
GPS: alkaline because my Garmin 2+ GPS needs a full 1.5V per cell, for its internal memory to work.
Camera: NiMH because they deliver the power required for plenty of
flash photography, and my latest camera has a NiMH setting that adjusts the voltage cutout.
Alkalines - I buy the Jaycar bulk pack - they seem OK to me.
NiMH batteries: I only buy japanese made cells - the 2500MAh Energisers are good. I've had a duds in the past with the unlabelled ones from Jaycar.
315771
Follow Up By: Member - Andrew (QLD) - Thursday, Jul 17, 2008 at 16:45
You've never had an alkaline battery leak in a torch or five, Phil? :-)
Andrew
581964
Follow Up By: Member - Phil G (SA) - Thursday, Jul 17, 2008 at 18:41
Gday Andrew,
Fair point. I've had the rare alkaline battery leak - but can't remember any in a torch :-))
581990
Reply By: Member - Andrew (QLD) - Thursday, Jul 17, 2008 at 17:09
I find that there is no one battery type that is the best for every situation...."fit for purpose" comes to mind.
I will use Energiser Lithiums AA for some situations, NiMh (eneloops) for others and Alkaline (Duracells) for the remainder.
Shop around for AA Lithiums, as their prices can be expensive. I currently buy
mine in Bulk (6x4packs) for $2 each, to give you an idea of their price point. Anything more is just plain expensive (though it isn't exactly cheap at that price either).
Depending on the type of torch, ceratin types are better than others. I use some powerful (yet small) torchs (100 lumens) requiring AAAs and find that the NiMh will outlast the high quality Alkalines due to the very high current drain. Fortunately these types of lights are regulated so their light output will not deminish until a certain voltage level.
In a normal torch (mini maglite etc) i find that good quality alkalines will outperform the rechargables.
It really depends on your particular circumstances and what you require out of the device.
My latest charger is this one:
It is able to charge up to 10 batteries of AAA or AA types, individually (the ability to mix sizes is possible).....great for when i have to charge 3 x AAA's for one of my torches (most, not all, other chargers hate odd numbers of batteries). It also has a discharge function, though not as
well advanced as Mikes one. (doesnt do multiple discharges etc). Having a charger that can run off both 240v and 12v is handy for travelling.
Hope this helps.
Andrew
315781
Reply By: westskip - Thursday, Jul 17, 2008 at 18:45
Hi there
Don't know if this is relevant but if you buy a 9 volt battery such as fits a Dolphin Torch and then pull it apart you will find that it is quite often comprised of 30 odd AA or AA batteries. Last one that I pulled apart had the equivalent of 8 D size batteries inside. Very cheap way to buy batteries.
315804
