Thursday, Jun 12, 2008 at 07:35
Hi All
When filling your tanks, always fill them slow, that way eg, air comes
out at the same rate as water going in, no airlocks in tank or lines,
also just to make sure you have purged air out, turn on tap just as
tanks are just about full , that will let air out completely, another
thing is to
check to see if the outlet side of the pump has a
non-return valve to stop the water between the pump and your taps
draining back, some caravan manufacturers dont put them in to save
dollars, a little bit of advice from and old Plumber.
Daza
575412
