Tuesday, Jun 10, 2008 at 20:12
Hi Colin,
I think you misunderstood Wayne’s statement regarding mods to the ZD30 Patrol, or I misunderstood your statement “This was WITH ALL the mods”.
I’ll agree that Nissan haven’t really fixed the problem and I doubt that they could and still have the Di version meet Euro3 emission standards. All they did was increase the oil capacity, which as you stated gave the engine a longer life, but still many have failed.
From October 02 there were no significant changes in part numbers until late 04 when the GUIV was released and I think from memory it was only the MAF and something with the cylinder head and pistons that were changed. Plenty of GUIV’s have failed also, but they should live longer also.
As far as mods go, fitting a boost gauge is beneficial if your turbo over boosts, but won’t help you if it over fuels. An EGT gauge would have helped you there, but Wayne was referring to the mods that many people do to improve the life span of their ZD30 Patrols. These include bypassing the ECU boost control and fitting a manual boost controller. Lowering your boost and fitting a free flowing exhaust without a cat and blocking the EGR. Also fitting a crankcase oil catch can, intercooler fan and electric fuel pump will go a long way to improving the life of a ZD30 as long as it’s done early in the engines life.
These are “all the mods” that many have done to try and improve the life span of their ZD30 Patrols, and so far I don’t know of any of them that have failed. Personally I have gone much further than this with
mine and even run diagnostic software to monitor the engines sensors in an attempt to pre-empt any pending problems, but time will tell.
I don’t have too much faith in them, but they would be a great engine if they weren’t so problematic.
Good luck with the LC transplant.
Chaz
575115
