under the niassan patrol
Submitted: Sunday, Jun 08, 2008 at 17:26
The Geriatric Gypsies
for the nissan wizzes
under the rear of the 2003 gu patrol rhs near the diff is a bracket with a spring which appears to attach to brake lines can anbody tell me about this thing
steve
Reply By: Member - Ed. C. (QLD) - Sunday, Jun 08, 2008 at 18:19
Shane (SA) is on the money...
"A load sensing proportioning valve (LSPV) is incorporated in the hydraulic system to prevent premature locking of the rear brakes by controlling the hydraulic pressure, dependant on the weight of the load being carried in the rear of the vehicle. the valve is mounted to the vehicle under body and connected to the rear axle housing by a tension spring."
Courtesy of Mr.
Gregory;-))
You will note that there is a bleeder valve there which should be bled along with the caliper valves whenever the the hydraulic fluid is changed...
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
308569
