Sunday, Jul 06, 2003 at 18:37
Hi Michael
The bits that are bearings are made by bearing companies either to Nissans specs (must buy from Nissan) or a standard sized bearing. Nissan make the car, where as the Nissan bearing in a Nissan box is actually repackaged when they receive it from Koyo or NTN etc. It even has the brand on it, but a Nissan box and price. I would ring Repco and ask if they sell kits for the GQ, chances are they do now it hs been out of production for a while.
I bought two sets of 80 series swivel hub bearings (NTN) from the bearing place i usually go to, for the price of one set from Toyota, then gave the second set away as a favour to a friend.
The best instance of repackaging i can think of is pool chemicals like MSA11, which is 20ppm Potassium Manganese, or something like that.
It comes as 1 litre of fluid and is 20 odd dollars.
1kg of the stuff at the nearest plant nursary is $2, and that will make 50 litres of MSA11 if you add 50 litres of
water (1 cent worth)
Andrewwheredayathinkwer mike?
16370
