Hid Lights
Submitted: Tuesday, Jun 03, 2008 at 06:44
ThreadID: 58319 Views:7695 Replies:7 FollowUps:11
Hi,I have just fitted some H4 hid Hi/Lo kits to my 80 series I have run into 2 problems that are probably not as bad as they seem. Being a new concept to me and I have had a fair bit of time over the years
working on vehicles,the globes which I fitted to the outside inserts
have a metal sheild around them, so I was adjusting height etc last night but seem to get a shaded area when changing high to low and visa-versa. Also I have noted that the highbeam indicator light does not work nor do the inside highbeam lights. I had previously fitted spotties all lights run seperate relays and I spliced into the the wire from highbeam inside insert to trigger the relays.So since I have only used the plug and play feature using the plug from outside headlight
to connect hid kit I can't seem to be able to get my head around this
problem which more than likely laughing at me in the face.
Any help would be appreciated thanks Ray.
