Converting Grid Co-ordinates to GPS Lat/Long
Submitted: Sunday, Jun 01, 2008 at 22:26
Dolphin38
G'day all,
I am just getting into this 4WD/off-road "stuff" so please bare with me...!!!
I have just bought a number of books/guides such as the "4WD Days out of Perth" so that I can get an idea about
places to go and have trip notes as
well to provide guidance and information.
However, all the GPS Waypoints for the various
treks are referenced by
Grid Co-ordinates based on the WGS84 datum, eg., 0 408 079mE 6 484 597mN.
My question is... is there a way of converting these co-ordinates into Lat and Long (deg min sec)?? Or do I need to get maps that have both the
grid reference and Lat-Long scales/markings so that when I plot a
grid reference, I can work out what the Lat-Long is?
Reply By: equinox - Sunday, Jun 01, 2008 at 22:39
Hi Dolphin,
Any decent GPS should be able to convert for you.
Otherwise have a look at this site:
http://www.ga.gov.au/geodesy/datums/calcs.jsp#coords
307260
Follow Up By: Zebra400 - Monday, Jun 02, 2008 at 04:03
This link is good as it gives you an online conversion and a downloaded excel spreadsheet just in case you want to convert when you are out and about in the bush.
I am intrigued why you want to operate in lot long? If you are using detailed maps, you will find
grid references much easier to work with as the
grid lines are either 1km or 10 km apart, and the
grid lines are straight.
573150
Reply By: Bonz (Vic) - Sunday, Jun 01, 2008 at 22:57
Those references are UTM. Just set your GPS up for UTM rather than DD MM SS.S or DD MM.MMM (i.e. lat/long) and you'll be fine. If youo must stay with lat/long then set the GPS for UTM and input the waypoints then set it back to lat/long and the GPS will automatically convert the coords.
307264
Reply By: Dolphin38 - Monday, Jun 02, 2008 at 00:25
Thanks very much for the info... most useful.
Cheers.
307277
Follow Up By: Member No 1- Monday, Jun 02, 2008 at 12:52
much easier to work out where one is on paper maps in UTM
573189
Reply By: Zebra400 - Monday, Jun 02, 2008 at 04:11
Make sure when doing your conversion that you use the right zone. Australia is divided up into 8 zones, from 49 - 56. Put the wrong zone with the same
grid co-ordinates and you will end up in a different location.
See below
Image Could Not Be Found
307282
Reply By: KennyBWilson - Monday, Jun 02, 2008 at 09:00
Hi Dolphin38,
I find the best way is to change the settings in Ozi-Explorer add the way points in and then change settings back to the way you want it.
Thats if you got a Laptop and Ozi installed , otherwise like some suggested change the settings on GPSr
307290
Reply By: Member - res.q.guy (VIC) - Monday, Jun 02, 2008 at 10:38
Hi Dolphin
A really good reference for newbie's, on gps, maps and navigation etc, is "GPS Vehicle Navigation in Australia" by Robert Pepper.
Have a look at :
www.gpsvehiclenavigation.com
Neil
307298
Reply By: Member - John R (QLD) - Monday, Jun 02, 2008 at 21:06
If you want to do this for a whole lot of waypoints though you might be better off seeing if you can buy a computer file version, then run them through a program that can read the format and even upload the points into your GPS if you have a data cable. G7toWin is one such free program, but there are many.
307388
