roll out awning tensioning
Submitted: Sunday, Jun 01, 2008 at 13:08
ThreadID: 58253 Views:1847 Replies:2 FollowUps:1
i have a roll out awning on my van and would like to know how to tension it up, any help would be appreciated. cheers
Reply By: Dunco (NSW) - Sunday, Jun 01, 2008 at 14:20
G'day,
Once I have mine rolled out and before I tighten the arms up, I tension it by turning the lever to close and roll the awning so it is tensioned up some, then I pull down on the awning and tighten the arm off
This way the awning finishes over the barrel if you get my drift...and by doing this water cannot fill the awning either.
This is the correct method of doing it...very hard to put in words as you can see, but try to ROLL barrel of the awning away from the van.
AnswerID: 307111
Follow Up By: zacc - Sunday, Jun 01, 2008 at 18:42
thanx for that dunco but that is not what i meant . i want to know how to tension the awning up for when it is rolled up back to the van , cheers
FollowupID: 573032
Reply By: Patrol GU IV - Sunday, Jun 01, 2008 at 17:28
What Dunco has said should do the trick.
For some hints on using your awning check here :http://www.theawningman.com.au/producttips.html
Neil
AnswerID: 307155
