landcruiser fuel hammer
Submitted: Wednesday, May 28, 2008 at 19:14
ThreadID: 58103 Views:3631 Replies:6 FollowUps:4
can anyone tell me if possible ,the part/part number from Toyota, of the said 'fuel dampener' required to adress this annoying noise that local Toyota dealers claim ignorance of. Appreciate any useful info. Cape adventure in 6 weeks.
Reply By: Member - Phillip S (WA) - Wednesday, May 28, 2008 at 20:00
What is it and what model toyota do you have........never heard of it
AnswerID: 306364
Follow Up By: Member - Davoe (Yalgoo) - Wednesday, May 28, 2008 at 21:00
Its in the TD yota utes (previos model) an yep its real, makes them sound like somesort of bizare wind up toy
FollowupID: 572372
Follow Up By: disco driver - Wednesday, May 28, 2008 at 23:19
I always thought they were a windup toy.
It's just a wind-up.
Disco.
FollowupID: 572402
Reply By: Member - 120scruiser (NSW) - Wednesday, May 28, 2008 at 20:33
If its a petrol engine, just double the length of fuel return hose. The commodore V6's were common for this and by doubling the line length seemed to fix it.
AnswerID: 306369
Reply By: donk - Wednesday, May 28, 2008 at 20:46
The fuel hammer fix was for the first of the HDJ78/79 series cruisers
Is this what you have ????
Regards Don
AnswerID: 306371
Follow Up By: Graham & Lynne - Wednesday, May 28, 2008 at 22:03
donk
what is the fix for this fuel hammer as one of my customers has it
Thanks Graham
FollowupID: 572387
Reply By: Member - Phil G (SA) - Thursday, May 29, 2008 at 12:10
As Don has said, the fuel pipe vibration was a problem with the first of the HDJ78/79's.
The fix is to fit the dampener that Toyota supplied from 2003 onwards. Toyota did it on mine after I demonstrated the noise.
It looks like this:
Image Could Not Be Found
AnswerID: 306469
Follow Up By:- Thursday, May 29, 2008 at 21:05
Thanks to all who replied, appreciatie your input/interest,will pass info to my competent mechanic. Would'nt mind doing nothing but SWMBO says its embarrassing with the noise that sounds so unTojo.
FollowupID: 572551
Reply By: Dunedigger - Thursday, May 29, 2008 at 16:27
Mine 2003 does it too. SOunds like a exhaust brake. Cuts in on deceleration at about 1200 rpm and stops aging at 1050 rpm. Once warm it does not happen. Does not bother me now, I know what it is
Dunedigger
AnswerID: 306539
Reply By: donk - Thursday, May 29, 2008 at 20:56
The part numbers needed for the damper,hoses & clamps are in a TSB (technical service bulletin) that any dealer can access
The damper is fitted inline in the fuel pipe (replacing a hose) & takes about 15-20 mins to fit
Regards Don
AnswerID: 306604
