Tuesday, May 27, 2008 at 05:52
If you're going to drive in the High Country I strongly suggest you practice this technique before you do:
THE STALL START or KEY START
When a vehicle stops on a steep
hill, don't panic. Think and stay calm.
1. Brakes on - both foot and handbrake.
2. Switch engine off if not already stalled.
3. Ease clutch in.
4. Select low range, reverse gear. Clutch out.
5. Check to see if track is clear to reverse and that the wheels are pointing straight ahead, not on an angle.
6. Handbrake off.
7. Footbrake off - but keep it ready for action.
8. Keeping your foot away from the clutch, start the engine and proceed backwards slowly down the
hill. Don't touch the clutch or the accelerator.
9. Slight 'feathering' of the brake is possible, but take care.
NB: 1. With autos, if the engine has stopped, you'll need to start the vehicle in neutral, or
park, before reverse gear is engaged (step 4).
2. If at all in doubt, chock your vehicle and use a winch to aid the descent or ascent!
Lifted from some website.
Mike Harding
572085
