Gosse Bluff NT
Submitted: Thursday, May 22, 2008 at 14:24
rredbeak
Has anyone recently been there please. My maps show a bitumen road,but the info center said its extremely rough 4wd only track...
anyone,,, please ??? cheers PJ
Reply By: Member - Davoe (Yalgoo) - Thursday, May 22, 2008 at 15:14
get a better map.its dirt but, a bit corraated butnot 4wd only
305287
Follow Up By: rredbeak - Thursday, May 22, 2008 at 15:55
TY davoe.i get my maps off the net then print out the ones im going to use...looks like i need a better site. Cheers.. PJ
571289
Follow Up By: equinox - Thursday, May 22, 2008 at 16:04
There is bitchumen right to the turn-off. Then the last 500 metres or so is dirt.
I can't remember where the blacktop starts and finishes. It goes at least from
the loop road to
Tylers Pass.
You don't need a 4wd. I got right up to
the crater in my 4 cylinder Corolla.
571292
Follow Up By: Member - Adam S (SA) - Thursday, May 22, 2008 at 16:16
equinox did you get to up to
the crater, or inside
the crater with the Corolla.
I would suggest to get inside
the crater your Corolla would have to be lifted and locked, unless things have changed since I have been there.
Adam.
571296
Follow Up By: equinox - Thursday, May 22, 2008 at 16:26
Adam,
I followed the track that heads inside
the crater until its end. (where the walk starts and the info signs are). That was in 2005.
Tracks a bit rough but doable.
571301
Follow Up By: Member - Adam S (SA) - Thursday, May 22, 2008 at 16:51
equinox both you and the Corolla did
I haven't been there for a while.The last time I went, was in the Troopy towing a trailer and I remember scraping things.
But in reality the Corolla has probably got better articulation.
Adam.
571311
Follow Up By: Member - Davoe (Yalgoo) - Thursday, May 22, 2008 at 17:20
are we all talking about the same place? off the Meerinie loop road?
I was there in 03 and t was dirt the whole way but would have been easily do able in a 2wd
571321
Reply By: HGMonaro - Thursday, May 22, 2008 at 16:21
Track in was more than 500m, I'd guestimate a couple of km. We towed our windup camper in and would agree a 2wd shouldn't have any problems however it is a bit bumpy in spots. Slow and steady (need to really as it's pretty narrow) and you'll be right unless your driving something "slammed" to the ground.
Nige
305306
Follow Up By: Member - John R (QLD) - Thursday, May 22, 2008 at 21:03
Yes more like 6 km if Google Earth is to be trusted. Certainly access has completely changed from 98 when we were there!
571352
Follow Up By: equinox - Thursday, May 22, 2008 at 21:21
Yes - I stand corrected. I must expand my memory cells a bit more when I post.
571354
Reply By: Member - Mfewster(SA) - Thursday, May 22, 2008 at 16:21
I haven't been there for about three years, but I would have thought that a standard car could be driven in, with a little care, without much trouble. It is also worth checking the display on Gosse
Bluff in the Museum of Central Australia in Alice. Also worth going to the
lookout at
Tylers Pass to get a good perspective on
the Bluff
305307
Reply By: rredbeak - Thursday, May 22, 2008 at 17:03
yes,ill do
Tylers pass and the gorges and chasms while we're there. Cheers and TY all.. Cheers..PJ
305314
Reply By: Member - Rob S (NSW) - Thursday, May 22, 2008 at 17:12
Hi the track from the turnoff is just a bit sandy corrigated as usual.
This photo of the track is about 2 years old.
The sign shows 4WD only probably if it was wet?
Image Could Not Be FoundImage Could Not Be Found
305318
Follow Up By: Member - Davoe (Yalgoo) - Thursday, May 22, 2008 at 17:24
4wd is necceasay---- If yo drive off the track. At about the sotof that pictre drove up the bank tolet a guy with a CT past and when driving offthe back left bogged down and the front right lifted up as it wasover the bank going back onto the road------ DUH
bit of air out of the rear left and I was on my way
571323
Reply By: Anthony (Vic) - Friday, May 23, 2008 at 13:09
We towed our Jayco Outback
camp into Goose
bluff while on route to
Glen Helen
305452
Reply By:- Saturday, May 24, 2008 at 21:24
I was there on Thursday (22 May 2008) for work.
The road just after
Hermannsburg (about the first 15km) is quite corrugated. Quite frankly, it sucks and as long as I've lived in
Alice Springs, this bit of road has always sucked!
However, once you reach the Desert Oaks (those funny looking trees) until the Ipolera/Gosse
Bluff turn off, it's a much better gravel road. There's about 10km of bitumen after this, all the way to the turn off into
the crater itself. The track into Gosse
Bluff (its proper name is Tnorala -which is kind of pronounced Noh-RUH-lah ... I won't go into the how to pronounce the Tn sound!) is officially a 4WD track, but unless it's been raining, you won't need 4WD and a soft-roader could do it easily.
I travel this way for work often and my partner is one of the rangers for the Parks and Wildlife Service.
305667
