Land Cruiser HJ61 - 24 Volts Imported - Parts
Submitted: Monday, May 19, 2008 at 15:10
Pelesino
I have a HJ61 Imported Cruiser 24 Volts, trying to find an alternator and other parts. Anybody knows where could I find a reasonable priced parts supplier ?
Reply By: Isuzumu - Monday, May 19, 2008 at 15:22
Try BMI (
Brisbane Motor Imports) (07) 32746611
I know of a couple more just have to find them.....google Jap imports might find some there
Cheers Bruce
304709
Reply By: Saharaman (aka Geepeem) - Monday, May 19, 2008 at 20:49
HI Pelesino,
One of my HJ61's is a 24 volts so I will be interested in what you discover. Please post your outcome if you can.
Also I have a question. Do you have a van or C/T that has electric brakes? If so how did you deal with converting the 24 volts to 12 volts for the brakes (and 12 fridge etc).
Hope you can locate the parts you need.
Glen
304753
Follow Up By: Pelesino - Friday, May 23, 2008 at 09:26
Hi Glen,
So far I've been able to find that the engine 12HT is similar to the one you find in the Toyota Coaster (Bus), so parts will not be an issue. The electrical system is different due to the size of the vehicle.
Are you able to tell me the details of the alternator that is in your Sahara ? Need a new or reco alternator, cannot find one. Give me the Model/Make/AMPS/Voltage and any other info you could find.
Mine is NipponDenso 24v
Any info will help
571408
Follow Up By: Saharaman (aka Geepeem) - Friday, May 23, 2008 at 13:34
The 12HT motor was also used in the Australian delivered models so I would have thought it would be the same.
I checked my alternator and it has the following label:
43 Regulator Built In
Toyota
27040 - 68030
100213 - 0520
24V
Denso
Hope this helps,
Cheers, Glen
571467
Reply By: autosparky - Tuesday, May 20, 2008 at 00:13
there is another aftermarket, baxters ,or ashdowns /ingrams ,aec
304795
Follow Up By: k1w1 - Tuesday, May 20, 2008 at 06:27
Hi Saharaman
We just finished a 3 year trip around towing a KK C/T in our 61 series. We fitted a converter just before the trailer plug. It is specifically designed to convert 24v to 12v for trailer wiring. i.e. 7 (I think) wires in 24v, 7 wires out 12v. Really expensive though at about $350.00 3 years ago.
Cheers Alan
570844
Follow Up By: Saharaman (aka Geepeem) - Tuesday, May 20, 2008 at 06:39
Thanks Alan,
I will
check it out. I had a feeling it might be a bit exy,
Glen
570845
