Franz Filter
Submitted: Saturday, May 10, 2008 at 22:45
Member - SNAKE QLD
Hi, Anyone running Franz oil filter system? What do you think of them and how far have you extended your oil change interval? Cheers. Snake and Josie
Reply By: Member - SNAKE QLD - Saturday, May 10, 2008 at 23:17
Should read Frantz.Snake
303147
Reply By: Member - David P (VIC) - Sunday, May 11, 2008 at 13:07
The question I would ask is does it filter out the additive package the lubricant engineers put in?.....silverback
303225
Follow Up By: STAN - Sunday, May 11, 2008 at 21:31
I have a Frantz filter on my Pajero 2.8 ITD . Have extended the oil changes from 5000 to 30000k with regular oil analysis from William Adams in Melb. No doubt this could be extended further and I will probably do so. The oil adatives get replentished every 5000k with the Frantz filter change [1 litre oil + a
toilet roll]. The particulate count is the same at 30000 as is at 5000. I have read where some opperaters have extended out to 100000k, but I would not recomend that without proper oil testing along the way. Hope this helps Stan
569444
