Tyre casing storage
Submitted: Thursday, Jun 26, 2003 at 21:17
ThreadID: 5684 Views:2222 Replies:5 FollowUps:13
Having an aversion to carrying anything heavier than my long handled shovel and UHF aerial on the roof racks and needing a spare tyre casing I have made a Masonite base (415mm dia) which fits onto the bottom of the tyre beading and is held in place with an internal brace and a top of 460 dia which just sits above the beading. So far we have managed to fit into the tyre the tent, tent pegs, 2 recovery straps, couple of fluro lights, tyre repair kit, small pump and ½ dozen shackles. Last time I put tinned food in it and it took two of us to lift it. We have noticed the more we travel the less we take.
Trev
Reply By: enzo - Thursday, Jun 26, 2003 at 22:14
Got any pictures?
AnswerID: 23600
Follow Up By: Member - Trevor - Friday, Jun 27, 2003 at 06:47
Enzo - I don't think you can post diagrams on this site. Drop me your email and I'll send you one.
Trev
FollowupID: 15797
Follow Up By: enzo - Friday, Jun 27, 2003 at 16:03
enzo@bundubasher.com
Thanks.
FollowupID: 15832
Follow Up By: Member - Bonz (Vic) - Friday, Jun 27, 2003 at 23:16
yer I'd like to see it too, gbarby@datafast.net.au, sounds like a good idea
Laterally literalSo many places to go!
So much work to do :0(
FollowupID: 15863
Reply By: Steve - Thursday, Jun 26, 2003 at 23:07
Y do u need a spare tyre casing ?
AnswerID: 23607
Follow Up By: ExplorOz Team - David - Friday, Jun 27, 2003 at 01:20
Steve,
Did you receive some form of error when you submitted this answer. I am trying to track down these duplicates that seem to be appearing - I will delete the duplicates below. Any help people?Regards
Always working, not enough travelling ;-)
FollowupID: 15795
Follow Up By: Member - Trevor - Friday, Jun 27, 2003 at 06:45
It is just a safety thing as my tyres are not a normally available size. It's the same as carrying straps - hope you never have to use them.
Trev
FollowupID: 15796
Follow Up By: Member -BJ (Sydney) - Friday, Jun 27, 2003 at 07:10
David it seems when you hit submit button it goes to a not found page so you hit back & submit again , depending on how many trys how many duplicatesRegards Bob
27th June Gulf trip
FollowupID: 15798
Follow Up By: Member - Rohan K - Friday, Jun 27, 2003 at 09:10
David, when I had this problem on Tuesday or Wednesday, after hitting the submit button I got a "Border manager" error page open. If I tried to clear that by hitting refresh or the browser back button, I'd eventually get back to ExplorOz. However, my post was being duplicated for every time I hit one of the above buttons. The only way to avoid it was to choose Home, or some other website from favourites and then start again. It hasn't happened to me since Wednesday but I notice Steve suffered multiple duplicates on postID: 5668Smile, you're on ExplorOz
Rohan (Sydney - on the QLD side of the Harbour Bridge)
FollowupID: 15804
Reply By: Old Jack - Friday, Jun 27, 2003 at 09:36
Trevor, what a good Idea!
I have subscribed to the pack tight travel Light philosophy for some time now, while I do carry an extensive kit of recovery gear, and by nature of my work tools never leave the truck anyway. I stick to just the basics. The next few trips will be longer ones & carrying a spare casing will be necesarry, Do you put anything inside the casing to prevent rubbing the inner surface?
AnswerID: 23629
Reply By: Member - Trevor - Friday, Jun 27, 2003 at 09:49
Young Jack - The tent and straps are soft. The pegs are in a bag and the shackles are in the soft stuff as well. It keep it full now to stop, try to stop, vibrations. When we did the Simpson I had some food in there along with some packets of milk. One packet ended up with a hole in it and we almost had an omlette!
Trev
AnswerID: 23631
Follow Up By: Old Jack - Friday, Jun 27, 2003 at 10:38
Trev,
this is what I was wondering about, we did a trip back in the 80's with a bunch that packed a heap of tinned food, after bouncing around all the lables had fallen off or rubbed un readable, each night they has "surprise" tea! writing on the lid of the tin with a marking pen helps, so does wrapping the tin's. shame about the beer they lost when the alloy cans rubbed through."No officer we are not Drinking as we drive"
FollowupID: 15812
Reply By: Member - Willem- Friday, Jun 27, 2003 at 10:41
As you can see from my pic I carry a spare casing, tube and gater on the bonnet of the truck. It works well and is held on by straps which hook up to a galvanised frame which is bolted to the bonnet. I also carry a variety of stuff inside the casing. The only problem I have encountered so far is rain water dripping into the casing. Have to work on that one and have some ideas.
Lifting the bonnet something else !! But this system works for me and casing does not block my vision as I sit high in the old truck.Cheers, Willem
Never a dull moment
AnswerID: 23635
Follow Up By: bruce.h (WA) - Friday, Jun 27, 2003 at 11:14
Willem have you tried puting a wheel cover overit before you strap it down that should keep the water out
regards Bruce
FollowupID: 15814
Follow Up By: Member - Willem- Friday, Jun 27, 2003 at 12:10
Bruce,
Yes, I had that in mind as an option. Have to get down to the Big Smoke however to find such an item as those covers are not found out here on the edge of the outback.Cheers, Willem
Never a dull moment
FollowupID: 15818
Follow Up By: bruce.h (WA) - Friday, Jun 27, 2003 at 12:16
willem have you had alook at the exploroz covers in the shop im sure they can be posted direct to you , or if you re moreinterested in just ablank one we sell them as blanks 7 can organise shipping
Regards Bruce
FollowupID: 15819
Follow Up By: Member - Willem- Friday, Jun 27, 2003 at 12:29
Bruce,
Can't seem to find the cover in the shop? Where is it listed?
Re your blank cover for 750x16 tyre, please contact me with a price including shipping to Peterborough SA to my email address willem@kempen.id.au
Thanks.Cheers, Willem
Never a dull moment
FollowupID: 15821
Follow Up By: bruce.h (WA) - Friday, Jun 27, 2003 at 12:47
wille
under exploroz merchandise
will email price asap
Regards Bruce
FollowupID: 15823
