Lower low range
Submitted: Wednesday, Jun 25, 2003 at 23:49
ThreadID: 5665 Views:1593 Replies:4 FollowUps:7
Hi all
Just been reading all the posts about getting lower low range gears, and just think it might need clarifing, i know this might start a argument but this is what ive worked out.
The rule for going up hills is use second low, this is because first low is to torquey, and the torque exceeds the availiable traction, this equals wheel spin. Im positive about this because ive tried 1st low up a hill(it was the first and last time :) So unless you have dramaticaly changed your tyre diameter have a lower low range will just be detrimental to your 4by.
Correct me if ime wrong cause im not getting gears because of this reason.
Regards Ben.
..................Insert witty comment here.......................
