ABS LIGHTS ON
Submitted: Sunday, Apr 13, 2008 at 20:51
ThreadID: 56605 Views:1665 Replies:7 FollowUps:2
hi there i have an nm pajero 3.5 and the ABN light on the dash has just come on , the hand brake light also is on . any body have an answer . the brakes are all good just the lights on . i also tried to see wether the abs works and it does not .
Reply By: Member - Littleborgy (SA) - Sunday, Apr 13, 2008 at 21:10
Hi Zacc,
My missus' stepfather had a VS Commodore which done that... Turned out to be a faulty sensor.
Hope this helps.
Cheers, Brad
AnswerID: 298349
Reply By: Member - BUNDY BOY (WA) - Sunday, Apr 13, 2008 at 21:19
hay .Zacc ..mate had the same prob..have u been in any major water lately??? we were away and playing in da mud n water .....all it was was moister in the wiring under car....all of a sudden it righted itself when it dried out
Cheers Bundy
AnswerID: 298354
Reply By: zacc - Sunday, Apr 13, 2008 at 21:46
na not been in any water, just had my head under the bonnet having a look see and when the ingnition is turned on the accumilator does it thing then there is like a screech coming from the master cylinder itself , like one of the valves might be stuck or something . i have not changed the fluid as yet and the car has done 110 00o klm , i was just thinking that might have something to do with it lioke a bit of condensation or some thing.
AnswerID: 298362
Reply By: Zebra400 - Monday, Apr 14, 2008 at 04:36
Simple answer is, if the light comes on then your ABS is not functioning. If the light continues to stay on, then have it checked out. Our light came on last year. We had it checked out. We had to replaced one of our sensors as it packed.
AnswerID: 298389
Reply By: MrBitchi (QLD) - Monday, Apr 14, 2008 at 07:45
Have a look at the Hazard light fuse.... under the bonnet..
Some weird symptoms appear when this fuse blows, and its pretty common. Happens when you have a trailer attached and lock/unlock the car, causing the hazard lights to flash, overloading the circuit ('cause of the extra lights on the trailer) and blows the fuse.
If this is the problem, simply replace the 10 amp fuse with a 15 amp one.
AnswerID: 298398
Follow Up By: Ircon - Monday, Apr 14, 2008 at 15:28
Yep,
Happened to me when I left the hazard lights on with the caravan attached.
Maybe ask the question on the Pajero Club Forum
www.pajeroclub.com.au
FollowupID: 564537
Reply By: donks1 - Monday, Apr 14, 2008 at 07:55
HI there
did you have the recall done ???
replacement accumulator should have been done
Donks
AnswerID: 298401
Follow Up By: zacc - Monday, Apr 14, 2008 at 12:07
no recall on my model , rang MM and they said mine falls after the faulty accumilator.
FollowupID: 564520
Reply By: time waster - Tuesday, Apr 15, 2008 at 08:25
Mine was the same turned out to be the right rear wheel sensor and at $400 I just took the globe out of the dash.....no ABS though.
AnswerID: 298616
