cleaning drinking water tanks
Submitted: Saturday, Apr 12, 2008 at 22:35
ThreadID: 56573 Views:3049 Replies:6 FollowUps:7
Hi, looking for ideas on how to clean a drinking water tank under a caravan that has had water siitting in it for at least 6 months?
Reply By: Member - bungarra (WA) - Saturday, Apr 12, 2008 at 22:40
chuck a few teaspoons of carb soda in and slosh it around........might have to take it for a drive to do that I guess...flush throughly afterwards
VKS 1341
AnswerID: 298178
Reply By: Member - Doug T (FNQ) - Saturday, Apr 12, 2008 at 22:54
Just undo the bung and drain it , stick the hose in let it run for 4 minutes .that's all I do and much to some's displeasure ...I'm not dead yet..
AnswerID: 298185
Follow Up By: Member - David P (VIC) - Sunday, Apr 13, 2008 at 11:27
.....but we're working on it......TIC...silverback.. (-: :-)
FollowupID: 564343
Follow Up By: Member - Doug T (FNQ) - Sunday, Apr 13, 2008 at 11:38
Thanks ya asshole ....TIC
FollowupID: 564349
Follow Up By: Member - David P (VIC) - Sunday, Apr 13, 2008 at 14:38
oops, forgot it wasnt Friday...... :))....silverback
FollowupID: 564372
Reply By: hazo - Saturday, Apr 12, 2008 at 23:02
Empty tank(s) then refill with fresh water, add half a cup of plain bleach (white king or similar) go in van and open each tap in turn till you can smell the bleach, then close tap . Do this to all outlets!
Then fill tank up to brim again, leave overnight ,then empty out tank again and flush with fresh water run all taps till no bleach can be smelled then re fill tank and water will be fine.
We had "gardia" bug in our tank from some suspicious water supply in Broome, It nearly killed my wife and she spent a week in bed, and this how we were told to clean out tanks and hoses etc.
Never had any problems since and we prepare our tanks this way every year now.
AnswerID: 298186
Follow Up By: scottyJ - Saturday, Apr 12, 2008 at 23:24
Thanks for your response, bleach sounds like a good idea for sure.
FollowupID: 564288
Reply By: mattie - Sunday, Apr 13, 2008 at 07:21
Hi Scotty
go to a home brew shop and buy some keg and line cleaner and follow the instructions, this will dissolve everthing then rinse.
MATTIE
AnswerID: 298208
Follow Up By: Sand Man (SA) - Sunday, Apr 13, 2008 at 09:59
I'm not sure about this Mattie.
I tried this and was advised by the store owner that the line cleaner actually needs a continous flow to work it's wonders.
I settled on Milton's Baby Bottle wash from the supermarket because it gives you the amount to use per litre of water.
From memory, 50ml per litre.
Swimming pool chlorine (liquid) is cheaper again, but is harder to work out the quantity needed to disinfect a water tank.
Bill
FollowupID: 564326
Reply By: mattie - Sunday, Apr 13, 2008 at 07:24
Scotty
make sure it is a caustic solution some shops will try to sell a metaphosphate or pink stain one product is Yuns keg and line cleaner
Mattie
AnswerID: 298209
Follow Up By: Member - Graham H (QLD) - Sunday, Apr 13, 2008 at 10:23
Easy get some Tank Kleener from Camec or camping shops and follow the instructioons
FollowupID: 564328
Reply By: scottyJ - Sunday, Apr 13, 2008 at 13:38
Thanks all for your suggestions on cleaning water tanks. Ta
AnswerID: 298259
Follow Up By: T-Ribby - Sunday, Apr 13, 2008 at 15:18
and once your tank is clean and refilled with water, you could always drop in water purifying tabs avail from your local pharmacy, or even better still run your drinking water through a filter
unit - both will take care of dicy h2o.
T.R.
FollowupID: 564386
