Cteck Battery Charger which one
Submitted: Thursday, Apr 03, 2008 at 19:20
Mike
I am going to buy a Cteck battery charger, which one do you think I shoud get? it will be to charge a 110amh battery in the Van and the main and duel batterie in the Landcruiser 100 series, also where will I get one at the right price in WA.
Reply By: feral - Thursday, Apr 03, 2008 at 19:51
This charger is value for money and it does everything the Ctek will do.
12V 16A Car Battery Charger
This fully automatic switch mode car battery charger utilises a four stage rapid charge design to optimize the life and performance of lead acid/GEL batteries. The pulsed current charging system allows batteries to accept up to 15% more energy than typical charging methods. Once the battery is charged, the unit switches to maintenance mode to keep the battery in peak condition. The charger has a number of other advanced safety features including automatic short circuit protection, anti spark circuitry, and reverse polarity detection. The charger also has a series of LEDs to indicate charging status and battery fault conditions. The ergonomic design includes a top mounted carry handle and cable storage for the battery leads and clamps. Size270(W) x 220(H) x 120(D)
Specifications:
* Spark free
* Output short circuit and reverse polarity
* Automatic thermal protection/shutdown
* Convectional cooling system
* Weather proof design
* Mains cable length 1.8M
* Battery lead length 1.9M
QTY
1+ $169.00
2+ $151.95
4+ $134.95
Jaycar has these terrific chargers.
296448
Follow Up By:- Thursday, Apr 03, 2008 at 20:10
I am pretty sure this is the same charger that Kmart have had on sale for $75 on and off over the past few months. I think you will find the numbers are all the same, just rebadged for sale at Kmart.
Used
mine for the first time yesterday on my new 100ah AGM Deep Cycle battery and it worked fine. From memory they have 4amp, 8 amp and 16 amp models.
562499
Reply By: Krakka - Thursday, Apr 03, 2008 at 20:43
Mike
Stick with the 25 amp C-Tek. Does everything a charger can do. Not cheap, does have a 5 year warranty, unlike the value for money Kmart one, it IS weatherproof, and it is an 8 stage charger.
Ebay is the cheapest, but could come unstuck where to take it if you have a warranty issue.
Cheers, Krakka
296465
Reply By: lifeisgood - Thursday, Apr 03, 2008 at 21:22
With value for money in mind , The Jaycar units of reasonable capacity are pretty good. I have a 12A unit which can also be switched to 6A for smaller batteries like my motorcycle SLA.
Have had it for a year and it worked
well in the van when I had a powered site. It has a small cooling fan which shuts down when the battery gets to charged maintenance mode. It is left on whilst my batteries are in storage and LEDs indicate battery state of charge (to some extent)
Check the Jaycar catalogue for other options Cheers
296480
