Fitting a genuine GU 4.2 Snorkel-- How hard is it?
Submitted: Tuesday, Mar 25, 2008 at 18:44
ThreadID: 55911 Views:2508 Replies:6 FollowUps:3
Wondering if anyone has fitted a genuine Nissan GU snorkel themselves. Or if you have had a poorly fitted snokel, fitted by a Nissan dealer. regards, Michael
Patrol 4.2TDi 2003
Somewhere you want to explore ? There is no time like the present.
Reply By: The Geriatric Gypsies - Tuesday, Mar 25, 2008 at 19:46
goodday micheal
I had mine fitted by a nissan dealer so that if the job was stuffed up i had some come back instead of wondering how i went about doing the job myself and what happens if i stuff it up
it was 1 job they seem to have done properly after some of the othe bits its been on for 2.5 years
steve
AnswerID: 294690
Reply By: Member - Luke (SA) - Tuesday, Mar 25, 2008 at 22:04
I fitted one (Nissan) to my patrol a few weeks ago. Wasn't all that hard to do really.
I took the guard off to do it. It took a whole day to do so be prepared.
I took the guard of to make it easier to cut the hole in the inner panel.
Mark all the holes, drill them and try the snorkel on to see if they all line up before you take the guard off. I had to elongate one of mine slightly.
When I put the A-pillar bracket on I had to pull the snorkel head down to the A-pillar about 25-30mm. There wasn't much stress on it.
The rest is pretty strait forward and is easy to follow in the instructions.
I sealed it up with sika-flex (urethane)
Hope this helps
Cheers Luke
AnswerID: 294734
Reply By: Wayne (NSW) - Tuesday, Mar 25, 2008 at 22:13
Michael,
When I had the 4WD shop and before that when I was fitting for another 4WD shop I fitted hundreds of snorkel over 10 years.
The best tip that I can give you is to measure twice and cut once.
Wayne
AnswerID: 294736
Reply By: ian.m - Wednesday, Mar 26, 2008 at 22:30
hi i fitted my kit, no guard removal 2 hours but have been in car industry, it can be done at home follow all intructions, and do double check before drilling, when you cut out paper template it is the important part, and wont fit precisely to the guard 'A' piller door seams, juggle the lines on the template to suit all the seams, there is enough room if you have to elongate the holes, and always repaint drilled holes to stop rust, something that is not done in dealer ships
AnswerID: 294928
Follow Up By: Member - Borgy.. (SA) - Wednesday, Mar 26, 2008 at 22:43
G'day Ian
what type of vehicle did you fit it to??
Cheers......Dave
FollowupID: 560838
Follow Up By: ian.m - Thursday, Mar 27, 2008 at 21:51
hi borgy, my rig is a 99 gu4.2td
FollowupID: 561065
Reply By: Steve from Top End Explorer Tours - Wednesday, Mar 26, 2008 at 22:36
Hey Michael.
Check out tread 55369, I did a piece by piece with photo's fitting a snorkel to a 100 series, It may help.
Cheers Steve.
AnswerID: 294930
Follow Up By: Steve from Top End Explorer Tours - Wednesday, Mar 26, 2008 at 22:38
Fitting a snorkel to a 100 series
Cheers Steve.
FollowupID: 560836
Reply By: Michael ( Moss Vale NSW) - Thursday, Mar 27, 2008 at 10:41
Thanks to all who replied, Michael
Patrol 4.2TDi 2003
AnswerID: 294975
