pioneer camper trailer water leak
Submitted: Monday, Mar 24, 2008 at 23:00
ThreadID: 55883 Views:4164 Replies:3 FollowUps:0
Have been trying to fix a water leak in a pioneer camper trailer since it was new. Have other owners of the pioneer campers had water leaks in and around the rear hinge? If so how did you stop it?
Reply By: Member - bungarra (WA) - Tuesday, Mar 25, 2008 at 10:13
G'day Austravel
We had a slight leak at the rear left but only after heavy rain once....was not able to find the source and hasnt happened since and so forgotten about it until your post.........it has not been tested in that sort of rain since..............or maybe lots of the fine red dust has filled it in somewhere hidden and done the job for us!
we have done some fairly deep water xings at times and not had a problem...so maybe that might be a clue that the water is travelling from somwhere on the body rather than entering immediately adjacent to where it is wet inside?
have you asked Pioneer?...from my experience they were a pretty decent lot to deal with and would be surprised if they werent able to help
VKS 1341
AnswerID: 294562
Reply By: Alan H - Tuesday, Mar 25, 2008 at 11:58
We had the same problem and it turned out to be the water filler hadn't been attached correctly inside the rear of the camper. I took it off put some silicon around it and reclamped it and no probs since.
You'll probably find as we have quite a few things need redoing due to inept assembly.
Hope this helps.
Alan.
AnswerID: 294579
Reply By: Austravel - Wednesday, Mar 26, 2008 at 20:20
Thanks guys,
Will keep you posted on this and other dramas.
AnswerID: 294882
