12/240V battery charger?
Submitted: Tuesday, Mar 18, 2008 at 17:21
ben_gv3
Do combined 12/240V battery chargers exist? I know there are 240V chargers (CTEK etc) and 12V chargers (solar regulators), but is there a combined unit?
If there are no units that do this, what precautions must I take to have a 240V and 12V charger both connected to a battery permanently? Diodes etc?
Also, with 12VDC chargers, are there other options then solar regulators that provide 3 stage charging? The only other non-solar regulator chargers I know of are 1 stage. I won't be using a solar panel but need the option for 12V charging.
TIA
Reply By: Member - Phil G (SA) - Tuesday, Mar 18, 2008 at 18:18
Ben,
Is an Arrid Twin Charge of use to you?
http://www.arrid.net.au/twin.html
293389
Follow Up By: ben_gv3 - Tuesday, Mar 18, 2008 at 21:16
Sorry mate.
The Arrid twin charger chargers dissimilar batteries from 8-15V. It won't charge from 240V.
Thanks anyways.
559084
Reply By: Derek from Affordable Batteries & Radiators - Tuesday, Mar 18, 2008 at 21:56
Hi Ben
Use a solar
grid charger / inverter. May be a bit big for your application and they are quite pricey.
Derek.
293471
Follow Up By: Derek from Affordable Batteries & Radiators - Tuesday, Mar 18, 2008 at 22:08
559099
Follow Up By: ben_gv3 - Wednesday, Mar 19, 2008 at 09:50
Hi Derek,
Big, pricey and looks bloody complicated too ;-p
559187
Reply By: Member - Mike DID - Tuesday, Mar 18, 2008 at 23:37
Buy a 12 volt input Charger (plenty of good ones for $100) and a 240 volt Power Supply that puts out 12 volts.
Dick Smith has a 23amp 13 volt supply that costs $99. It can also power your DC loads while at a powered site.
293505
Follow Up By: ben_gv3 - Wednesday, Mar 19, 2008 at 09:49
Thanks for that, this is sorta what I orginally had in mind. Can I have both chargers connected up permanently though?
559185
Follow Up By: Member - Phil G (SA) - Wednesday, Mar 19, 2008 at 12:30
Gday Mike,
What other 12 volt input Chargers are available for lead acid batteries? I only know of the Arrid.
phil
559211
Follow Up By: Nomadic Navara - Wednesday, Mar 19, 2008 at 14:20
You can have any number of chargers hooked up to your battery. I have a Twin Bharge, Durst 240 V charger and a MorningStar solar controller all connected to my battery. They do not fight each other and none of them drain the battery as they do not draw from the battery when they are switched off.
559233
Reply By: Dunaruna - Wednesday, Mar 19, 2008 at 17:54
You might want to consider a Balcatta smart switch. Looks very
well built and if it does what the maker claims it's a damn good idea.
293621
Follow Up By: Muddy doe (SA) - Wednesday, Mar 19, 2008 at 23:44
Got any more details of website or maker?
I Googled that name and only got hits for the town/suburb of Balcatta near
Perth.
Muddy
559417
