COROMAL MAGNUM 420- CAMERONS CORNER TRIP
Submitted: Monday, Mar 17, 2008 at 12:27
crusher060
We have a 4WD trip on next month to Camerons Corner via
Menindee,
Silverton,
Broken Hill,
Tibooburra & Whitecliffs and was after peoples thoughts on whether the camper will handle it
Approximately 600-700kms will be on dirt roads which I suppose will have some corrugations.
My camper is a Coromal Mirage 420. I have spoken to the local Coromal mechanic who does all their servicing and he believes the
suspension will cope fine as long as I take it easy where required.
He also mentioned that lesser quality Coromals have done similar trips ie
Oodnadatta track without incident
The
suspension is 8 leafspring independent, however the tyres are only 14 inch.
What are peoples thoughts on ability to handle?. Have any of you taken similar set up campers to this area.
cheers Mick
Reply By: Dave B (NSW) - Monday, Mar 17, 2008 at 13:56
Mick, the road between
Tibooburra and
White Cliffs has got quite a few
creek crossing through there, more particularly from Cobham through to Morambie.
Don't worry about the depth of the water, it's the possible gutters that might be through the
creek crossing that are the problem.
They will do a bit of damage to your
suspension if there is gutters there. It depends if there has been rain and if the
grader has been along after the rain.
If it does rain while you are in the area, you won't move too far.
The last 40 K's into
White Cliffs from Tib is also subject to some bulldust holes too, so just take it a bit easy through Morambie.
You didn't say which way you were going to
Menindee, but from
Broken Hill to
Tibooburra and CC is generally a good road and fairly
well maintained.
The roads north of
Broken Hill are maintained by the RTA, so you can
check the latest info on this site.
Far West NSW Road Reports
Dave
293107
Reply By: Member - DOZER- Monday, Mar 17, 2008 at 15:19
Go over all your van and replace any cable ties with wire, anything plastic, wire rubber infront of to take
the rock rash, even brake wires on axles, remove cable ties as the rocks will real quick.
On another note, make sure you have a look through the NPWS office in the main street of Tibboburra....they have a great re-enactment of Sturts party through the scrub, and you will quickly appreciate why the locals were throwing spears at them....
Andrew
293123
Reply By: Member - Hughesy (NSW) - Monday, Mar 17, 2008 at 22:30
G'Day Mick,
We are doing basically the same trip next Thursday. Starting at
Broken Hill then to Whitecliffs -
Tibooburra - CC -
Broken Hill.
We'll be towing a Jayco Dove Outback, so reply to this message again in the first week of April after I've returned and I will let you know what the roads were like.
As Dave B has said unless they have recent rain (and we haven't had any of that for a long while) then you shouldn't have any dramas so long as you drive to conditions.
I'm just hoping it cools down before next week!!!
293243
Reply By: crusher060 - Monday, Mar 17, 2008 at 22:56
ok thanks Hughesy will try to remeber to do that.
The Jayco outback has a lot higher clearance than my Coromal does, I'm reasonably confident the
suspension should handle the conditions okay it was more the clearance issue I was concerned about, but I think I will take the chance on it.
My wife will be a lot more happy if we take the Coromal rather than a tent
293248
