Exporting Raster Maps
Submitted: Monday, Mar 17, 2008 at 11:38
ThreadID: 55623 Views:1504 Replies:2 FollowUps:3
I am having problems exporting maps...if I try to export any maps bigger than about 50K (the size of export current view, when you go to a 250K sheet etc) it comes up "not responding" and wants to close down. And the ones I can load I have to go to Load & Calibrate Map Image format to do it. Is this the normal way to export these maps? (I have a reg copy of Natmap and Ozi)
Cheers Bruce.
Reply By: bennspoon - Monday, Mar 17, 2008 at 14:41
It takes ages because of the detail.
go to export it then go have dinner. depending how long it takes depends on how zoomed out you are. It will say not responding when it is processing heavily- just be patient.
AnswerID: 293111
Follow Up By: Isuzumu - Monday, Mar 17, 2008 at 17:51
Thank you for that.
Cheers Bruce.
FollowupID: 558802
Reply By: Member - Toolman (VIC) - Monday, Mar 17, 2008 at 19:10
Isuzumu,
Export from NATMAP Raster Premium goes something like this:
In the Raster package - Export current view and follow the prompts as follows:
Export- select "Geotiff"
Compression - select "none"
Resolution: chose the one that you want. The lower the resolution the poorer the final quality and the quicker it will export. Trial and error here to work out your preference.
Its here you tell the software where you want to store the exported geotiff image.
In Ozi: Under the "File menu"
Import map
Select Single DRG or if you have more than one, All DRG's on a CD or folder then locate where you stored the exported folder and follow the prompts. No need to calibrate the imported map. Its already calibrated.
Generally I've found if you are trying to export a file too large for the memory it will refuse to work and give a message saying not enough memory or words to that effect.
If I'm tellling you how to suck eggs sorry. I wasn't sure how much you knew.
regards
Toolman
AnswerID: 293172
Follow Up By: Member - Toolman (VIC) - Monday, Mar 17, 2008 at 19:12
I meant to write
......where you stored the exported MAP and follow the prompts...
toolman
FollowupID: 558828
Follow Up By: Isuzumu - Monday, Mar 17, 2008 at 19:27
Thanks Toolman, that handy, I am try to load one from Exporter now it has been going for 1.5 hours maybe a bit long I would think.
I knew about the "geotiff" etc but not about Import Map select Single DRG. ok thanks again.
Cheers Bruce
FollowupID: 558830
