Saturday, Mar 15, 2008 at 12:49
Gday Kim,
Im starting to think Ive spent too much time in the bush!
SHOWER!!!!!! Hahahahahah
When in Rome, do as as the Romans...
When In
the Desert , smell like a local.......
When I was working bush....usually part of the job was equiping a
bore.
I made a shower that was a steel clip together frame with a tarp around it, aluminium floor, electric instant hot water service running off a bloody huge 4 cylinder diesel geny and the water straight out of the
bore.
There were no 1 litre showers then....it almost took the skin off your back!
Other wise you drive the back hoe over to the
bore and fill the bucket, lay the bucket on the fire for an hour or so, back it up and hop in!
Only trouble was you knew who your mates were......when it got cold you'd yell out to some one to take you in for a re- heat...trouble was..getting some bastasrd to take you off when you started cooking, thats when you found out if youd given someone too much $hiit that day!!!!
If only the greenies and OH&S mob saw what we used to do.
Hairy
558359
