Yota Brake Recall
Submitted: Tuesday, Mar 11, 2008 at 17:30
Kev & Darkie
Now that Darkie is an official Queenslander and I can let out a sigh of relief. I have booked him in to get the Brake recall done for Tuesday next week.
From memory some people have been told that they (Toyota) wanted to do the wheel bearings at the same time.
What is the damage that Toyota do to yuor hip pocket when they do it or am I better off having a go myself if needed.
Cheers Kev
| Russell Coight:
Reply By: Member No 1- Tuesday, Mar 11, 2008 at 17:43
tell them "do whatever is necessary"....its a recall and you shouldnt have to pay for it....:))
292128
Follow Up By: Kev & Darkie - Tuesday, Mar 11, 2008 at 17:48
I like your thinking,
they should be doing the Bullbar recall at the same time as
mine is one of the ones that have the mounts fracture under load from winching. I expect that they would only fracture from pulling Nissans out ha ha ha
| Russell Coight:
557479
Follow Up By: Member No 1- Tuesday, Mar 11, 2008 at 17:56
can you actually pull a nissan out....i thought every thing just broke apart when trying
557481
Follow Up By: Krakka - Tuesday, Mar 11, 2008 at 20:40
Bearings are nothing to do with the recall. Like to see you say "do whatever is necessary" and then not pay for anything. Recommend you take a blank cheque and hand it over if you say that. Hope you were joking!!!
557524
Reply By: Member - barry F (NSW) - Tuesday, Mar 11, 2008 at 18:36
G'day there Kev, there are some excellent brake servicing facilities here in New South. Perhaps you could try
Sydney where there oodles of such people or maybe here in
Newcastle & we could have a beer or six while you were waiting to have the job done.
It would not be a good idea to have a go at doing it yourself, as I read a post the other day saying you were now a council worker.
If this is correct you would need to lean your shovel up against something & you might unwittingly lean it against Darkie, thus scratching the Duco? LOL & cheers
292139
Follow Up By: Kev & Darkie - Tuesday, Mar 11, 2008 at 18:38
Well at least you have XXXX in the fridge LOL
| Russell Coight:
557487
Follow Up By: Member - barry F (NSW) - Tuesday, Mar 11, 2008 at 18:44
Pleny of xxxx Kev but beginning to be hard to get at because of my ongoing problem with static electricity giving me a boot everytime, which is often, I go to open the frig door.
Maybe if I change to Super instead of mid strength it will deaden the shock? Cheers
557489
Follow Up By: Kev & Darkie - Tuesday, Mar 11, 2008 at 19:16
Maybe get SWMBO to get it for you ;))
| Russell Coight:
557494
Reply By: Steve from Top End Explorer Tours - Tuesday, Mar 11, 2008 at 18:42
Hey Kev.
I had my recall done in
Cairns when they did some work for me on holidays.
When I put the car in I told them that if they needed to do the brakes or wheel bearings, there was a set of each on the front
seat, along with the grease I would like you to use.
When I picked the car up the spare stuff was still on the
seat.
Cheers Steve.
292141
Reply By: Member - Graham H (QLD) - Tuesday, Mar 11, 2008 at 20:41
Got
mine done when they did the 70,000k service. Replaced studs and repacked hubs.
NO mention of bearings and at about $400 I believe, I guess they arent giving them away
292177
Reply By: Member - Phil G (SA) - Tuesday, Mar 11, 2008 at 20:59
Gday Kev,
When I had
mine done, they just replaced the bolts as required under the recall, and didn't touch the bearings.
292184
Follow Up By: Richard Kovac - Wednesday, Mar 12, 2008 at 01:01
Yer same here Phil.
Till I was haveing a look aroung and found 1 of the FWhub bolts missing, then looked harder and found that there was two spring washers on 1 cone stud and none on another. it started to rain (I was thying to get a free GOD wash) and I,m out replacing bolts and washers... gees it gives me the sts. call them they say sorry will supply new bolt next service.. LOL
I love Good service
Richard
557607
Reply By: redfive - Tuesday, Mar 11, 2008 at 21:47
Hi All
Got my letter the other day i had my bearings done about 6 months ago and we look at that bolts in ? showed not sign what so ever of been loose or anythink esle and as i dont trust my local toyota boys i wont be letting them go anywhere near my truck a mate got his done charged him for wheel bearings and disc pads which didnt need replacing
Glenn
292206
Reply By: Stu & "Bob" - Wednesday, Mar 12, 2008 at 14:19
Hi Kev,
Bob got his done last year, the cost for the "bearing re-pack" was $160.
When they do the recall, the bearings have to be disturbed to remove the hubs. However, I have had to adjust the passenger front bearing since. (did it myself)
HTH
Stu
292323
