Radiator Price for 1HZ
Submitted: Saturday, Mar 01, 2008 at 15:51
ThreadID: 55082 Views:1799 Replies:7 FollowUps:1
Hi all
Does anybody know the rough prices for a new and exchange radiator for a 1HZ cruiser?
I am fitting it myself, but dont know if whether and exchange or a brand new radiator is the best option?
It appears the current leaks are from the core, but i have had a leak once at the botton of the bottom tank, and a big dent in the top tank.
Thanks for your help.
Reply By: Footloose - Saturday, Mar 01, 2008 at 16:26
I had thought about 650 for a new one..so I had a water alarm fitted also. They charged me $1100 !!
Next time I'll go to a radiator shop instead of a 4wd one!
AnswerID: 290252
Reply By: Outnabout David (SA) - Saturday, Mar 01, 2008 at 16:32
Try Repco I think they had them for bout $350.oo
AnswerID: 290253
Follow Up By: Member - 120scruiser (NSW) - Saturday, Mar 01, 2008 at 16:46
I have had dramas with the ones from Repco. They appear to be cheapies and don't last. I would try a good radiator outlet.
FollowupID: 555591
Reply By: Member - Doug T (FNQ) - Saturday, Mar 01, 2008 at 16:56
Image Could Not Be Found
AnswerID: 290255
Reply By: howesy - Saturday, Mar 01, 2008 at 17:32
got an aussie desert cooler heavy duty triple bypass 4 core for $490 plus freight ($50 O/nite courier) Been using their radiators in several cars for a few years and wouldn't use anything else. Once you put one of theirs in cooling troubles are a thing of the past.
I still have the not very old 3 core factory unit if you get cash strapped and stuck.
AnswerID: 290260
Reply By: Member - Ian H (NSW) - Saturday, Mar 01, 2008 at 17:33
Hi Brian. I replaced in feb 06. $660 for a genuine one which was only slightly dearer than aftermarket.
When fitting it I turned the mounting bolts around the other way which made the job much easier. Good luck.
AnswerID: 290262
Reply By: Cruiserman1961 (QLD) - Saturday, Mar 01, 2008 at 19:43
Howdy Brian,
bought one last month from Natrad in Bundaberg for $495. Well made and fitted well.
Cheers, Udo
AnswerID: 290279
Reply By: Member -Signman - Sunday, Mar 02, 2008 at 12:01
If you're gonna replace- go for a 3-core unit.
Ours (exchange, new core, - with warranty) was $390.
Of course we put new hoses, cap, inhibitor etc while we did the job.
AnswerID: 290366
