Voltage Sensitive Relay theory
Submitted: Wednesday, Feb 27, 2008 at 11:31
ThreadID: 54978 Views:17567 Replies:9 FollowUps:54
Hiya Gurus,
I'm looking into the theory behind VSRs.
Now, when the 2 batts are connected thru a VSR the primary batt is connected to the alternator and the secondary batt is disconnected until the primary batt has reached 13.2v (I think that's the voltage). When the primary batt has reached 13.2v the secondary batt is now connected to the circuit and starts charging.
What happens when the secondary batt is very discharged (or is a deep cycle etc) and then connects to the circuit, won't the 2 batts now "equalise" thereby dropping the primary voltage down? I think it is also referred to as "voltage chatter" which is where the primary batt voltage drops below 13.2v thereby disconnecting the secondary batt.
Do the more complex (and more $$$) systems account for this?
Ben
