EGR Recall Gu Patrol 4.2TDI
Submitted: Tuesday, Feb 26, 2008 at 07:34
ThreadID: 54937 Views:2240 Replies:5 FollowUps:4
Had ours replaced yesterday and it had slightly more power but definitely a noise coming from either the valve itself or the turbo. It is only happening under load and I'll give it a week to see if it settles down. Has anyone else had the same experience. The vehicle is running a 3" exhaust right through.
4x4alburywodonga.com
Reply By: Peter McG (Member, Melbourne) - Tuesday, Feb 26, 2008 at 09:36
Had a new noise from where they forgot to replace the EGT probe!
VKS Mobile 1906
AnswerID: 289431
Follow Up By: madcow - Tuesday, Feb 26, 2008 at 10:10
I may drop in this arvo and ask that question.
FollowupID: 554744
Reply By: Member - Coyote (QLD) - Tuesday, Feb 26, 2008 at 09:47
Mine is going in next week. Ive put a watch on this post and will get back to you after it's been done. good to kno what to look for though thanks for the tip.. mine also has a 3" exhaust all the way through.
AnswerID: 289432
Reply By: trolute - Wednesday, Feb 27, 2008 at 17:46
I had mine done last week - no difference in performance, but a much louder exhaust sound, especially at low revs. thought maybe the exhaust needed to settle, left it a day, still no change, so I got under it, and the mechanics had left quite a few bolts out of the heat shields, and one of said bolts is tapped all the way into the dump pipe (MTS 3" dump and pipe) so exaust was coming out the bolt hole.
I fixed it myself, as I didn't want the mechanics near it again if they can't even put bolts in! (pickerings Mt Isa)
I was quite disappointed that they were so poor at their job
AnswerID: 289674
Follow Up By: madcow - Thursday, Feb 28, 2008 at 08:37
mmmmmmmmm Mine is a Denco dump pipe. It does not look like they removed the turbo shields but will get under with a mirror to have a good look around. It is in a bugger of a spot eh? Found that they had removed the oil filters to give a bit more room but they could have wiped the oil up from underneath as it was dripping in the garage.
FollowupID: 555109
Follow Up By: madcow - Tuesday, Mar 04, 2008 at 14:46
We took it back to get checked out and it is going back in again for another go. What exactly the issue was is a mystery at this stage as I was not there. Will post it up if they inform me what the issue was or where they buggered up. I am a confirmed believer as to why they will never get to service my car. It is obvious it was never road tested before i got it back!
FollowupID: 556164
Reply By: Ozboc - Tuesday, Mar 04, 2008 at 15:44
What year models did this recall apply to -- as i did not receive a recall notice at all ??
Boc
AnswerID: 290761
Follow Up By: Truckster (Vic) - Tuesday, Mar 04, 2008 at 16:40
they started the recall 1/Feb in alphabetical order.
Effects VIN number range between JN1 TCSY 61A 0345001 & JN1 TCSY 61A 0365922
call your dealer with your VIN to make sure.
FollowupID: 556178
Reply By: madcow - Tuesday, Mar 11, 2008 at 07:37
We got our vehicle back after another attempt to get it right and I was informed the studs had to be replaced as the pipe was not seating properly? When i questioned why it was not road tested in the first place he had no answer.. It is a lot quieter than it was before.
AnswerID: 292043
