Protective board on caravan water tanks?
Submitted: Thursday, Feb 14, 2008 at 09:46
Ron173
G'Day all,
I'm replacing a
water tank in an older van, I'm wondering what the importance is of placing wooden board in front and beneath the tank for stone protection?
I can see the reasoning, but I'm kinda thinking the tank is a big lump of plastic, which is going to deflect stones itself.
I dont have the original so would need to go buy board and cut etc.
Dont want to go to expense and trouble if its hardly worth it.
Do new vans have wood protecting the tanks?
Rgds
Ron
Reply By: Shaker - Thursday, Feb 14, 2008 at 09:50
Good off road camper trailers have
water tank protection, if you are going to be doing a lot of gravel roads etc, it would pay to protect your tank.
It would be better to get some steel folded, rather than timber.
287410
Reply By: Member -Signman - Thursday, Feb 14, 2008 at 09:59
Make up a 'template' out of cardboard. A sheet metal
shop will charge you a few bucks to knock it up out of 0.5mm or 0.8mm gal sheet...
When you install it- pack some foam rubber between the guard & the tank to stop even small stone getting in between & puncturing the tank...
287413
Reply By: Wizard1 - Thursday, Feb 14, 2008 at 10:00
Have a look at any van desiged to go off road, even gravel roads, they all have stone protection plates. They are sheet metal not wood as it wouldn't last too long.
I have both my tanks protected with galvanised sheet metal after gettig a hole in one caused by a
rock that you seem to think just bounce off.
Let me assure you the don't just bounce off. A little bit of insurace or arrive at the end of a drive with no water.
It cost a few bucks to take your measuremets into a sheetmetal place and get them to make one up.
287414
Reply By: Ron173 - Thursday, Feb 14, 2008 at 10:36
OK
Thanks for replies,
seems its worth it and sheet metal is the go.
As I havent started to fit yet, can take tank into wshop and have
tailor made.
Thanks again
287420
Follow Up By: Notso - Thursday, Feb 14, 2008 at 10:39
Also protect your pipes and drain taps on the tank as I know of many instances where a tap or pipe has been hit by a
rock and no water on arrival at destination.
552657
Follow Up By: Wizard1 - Thursday, Feb 14, 2008 at 13:46
I don't know why you need to take the tank in? You seem to be making the exercise harder tha it has to be,
The tank should be on the van and all you do is take the measurements so the protection plate just screws into the under side of the floor.
Here is a picture. Scroll dow the messages and you will see what I mean
Water Tank bash plate
552678
Follow Up By: Ron173 - Thursday, Feb 14, 2008 at 15:44
I follow what you mean.
I wasnt making it difficult, I havent fitted the new tank yet its in my ute, so easy to ask for a plate to fold around it.
I have still to start job and not removed old split tank yet.
Rgds
Ron
552697
Reply By: Trevor R (QLD) - Thursday, Feb 14, 2008 at 16:24
Ron,
If you are driving outback dirt roads, I would suggest some sort of protection. I will try to add a couple of pics of my
water tank guard after we got back from the Birdville Track.
Image Could Not Be Found
Hope this helps motivate you to get some sort of protection for your tank.
Regards, Trevor.
287470
Follow Up By: Ron173 - Friday, Feb 15, 2008 at 08:19
Thanks Trevor,
I dont do much dirt roads at moment, this van only does local runs, but your pics are quite convincing!
If I was to go on a big trip I'd prob upgrade the van to an off roader.
Ron
552834
Reply By: Jim from Best Off Road - Friday, Feb 15, 2008 at 18:19
Ron,
Not sure where you are located, but if you're in
Melbourne I'm happy to help you out. All you need is a sheet of 2mm alloy which I can get you at the right price.
Bring it and your tank into my factory and I'll cut it to size for you for bugger all.
Jim.
287654
Follow Up By: Ron173 - Monday, Feb 18, 2008 at 07:23
Thanks a lot for offer Jim, I'm in NSW though.
No worries I'll fix up something locally,
Rgds
Ron
553344
