Wednesday, Jan 30, 2008 at 23:25
Brad
You post-> ""i have the 2 fridges, & led lights and a 75amp hr n70z wet cell from a previous 4wd, but dont mind buying a new agm .
after reading the thread re: solar panels , i think i should rephrase the question, here goes, how much power will the 2 fridges use (MAXIMUM) in a 24 hr period ?
Buy 2 x new AGM's - give the wetcell to a family member lol
-> {Assumption: the fridge draws 2.5ah} 2 x 2.5ah each = 5ah x 24 hours = 120 Amps per 24 Hour day.
-> the lights after dark 5 Amps
two fans running at sleepytime another 20ah -> at least ???
the odd dvd on the laptop ->???
if i have 2 x 100ah batterys in parralel is it ok to discharge them to 50% daily and what wattage solar panels will i need to charge these back up to full capacity each day
-> when we know the Amps used we can answer the question, unless you will accept a realistic guess.
As MOST of you power consumption is used at night and no
solar power supplied during that time you have to be sure of the numbers relevant to the "fans" and "dvd on the laptop"
You will need at least a 85 Watt panel to replace the 5 Amps the 2 x fridge's will use during the day and maintain the voltage left in the battery at dawn.
Depending on the *QUALITY* of the AGM batteries, you will probably have close to 12.5 Volts in the battery at dawn, (My agm system is 12.8v each morning, running only 1 x 2.8ah F/F & lights etc) however a cheaper battery system will be lesser voltage.
If you have 2 x 100ah agm's you should have no major problem with power consumption, UNLESS the fan or dvd uses excessive power.
Solar panels should be able to replace whatever is used by fan and computer on inverter, my guess would be 2 x 100 or 2 x 120 Watt *quality* panels will suffice.
Mainey . . .
284630
Follow Up By: Brad40 - Friday, Feb 01, 2008 at 00:23
G'day Mainey,
after hours of surfin the net & the advice given on this site ,
i have decided on the following ......
2 x 120 agm batts , lots of recommendations on fullrivers so they might be the go , need to do some price comparisons first .
2 80w sharp panels , good price on ebay , combined will provide 9.2 amps /hr max (according to website )
i have decided to run the fridges on 150w
inverters as they have a 11.5 volt low battery alarm plus a shut off at 10.5 v . there $59 from dick smith & i can use them for the phone, cameras & laptop chargers when needed .
I will just have to wait & see if this works for me .
thanks for your advice much appreicated .
Brad
549627
Follow Up By: Mainey (wa) - Friday, Feb 01, 2008 at 00:49
brad,
I can **** you the Fullrivers...
I won't !! Get a quality AGM battery!!
Are these the Panel specs ?
80 Watt Maximum Power
21.3 Volt Open Circuit Voltage
17.1 Volt Maximum Power Voltage
5.30 Amp Short Circuit Current
4.67 Amp Maximum Power Current
14.11 % Encapsulated Solar Cell Efficiency
600 Volt DC Maximum System Voltage
As to the Inverter :-(
Will 150 watt run BOTH fridges ?
Don't worry about the alarm, you have to be there to do something about it.
I'm not telling you what to buy, just give you something to evaluate
Mainey . . .
549631
Follow Up By: Brad40 - Friday, Feb 01, 2008 at 11:09
G'day Mainey
what batts do you recommend ?
yes those specs are correct
already have 1 inverter for laptop & charging duties
549686
Follow Up By: Mainey (wa) - Friday, Feb 01, 2008 at 17:32
Brad,
as is pictured (below) I use "FirstPower AGM Deep Cycle" storage batteries.
NO, I don't sell them, but I'm prepared to pay their price because they are far more efficient than 'any' battery I have used or installed.
They don't look 'nice' or 'pretty' either, but they are a quality built battery.
Mainey . . .
549747
