Friday, Jan 25, 2008 at 11:33
Ric,
I'm no engineer, but I expect the reason these dual cabs bend is that the rear axle acts as a fulcrum, with almost all the load behind the rear wheels. This is the Navara from side on:
So the load in the ute is mostly behind the axle and if towing, the weight on the ball is a long long way back as
To stiffen the rear
suspension with an airbag, must increase the likelihood of it bending forward of the rear axle. These airbags can be very stiff and support a lot of weight. Airbags for my vehicle are able to support an additional 2200kg. Secondly, when you fit the airbags, you replace a rubber bump stop with some solid steel AND reduce the upward travel of the axle by over 70mm. So the likelihood of bottoming out at low pressures is considerable, and steel is not flexible.
In my (inexpert) opinion, the finger can be pointed in two directions:
The vehicle manufacturer should quote a lower payload for the dualcabs and secondly, the airbag manufacturers should warn prospective purchasers about the risk of a bent chassis with dualcabs.
548328
