285/75/16 on a 100s cruiser?
Submitted: Wednesday, Jan 16, 2008 at 08:52
ThreadID: 53539 Views:3188 Replies:14 FollowUps:8
Just wondering if anyone has this size tyre fitted.
How much is the speedo out,how do they handle, etc.
Currently running 265/75/16 Cooper ATRs at the moment .
Thanks in advance.
Damon.
Reply By: Kev & Darkie - Wednesday, Jan 16, 2008 at 09:00
Damon,
Darkie has this size in the infamous Cooper ST's ;)
The speedo reads just over ie reads 100km/h but actual is 103km/h.
Cheers Kev
Russell Coight:
AnswerID: 281891
Follow Up By: Member - Tour Boy (springsure- Wednesday, Jan 16, 2008 at 09:04
Kev have you moved up here yet?
Dave
Dave
2015 Fortuner
Had 72 cruisers in my time
FollowupID: 546296
Follow Up By: Kev & Darkie - Wednesday, Jan 16, 2008 at 09:06
I am moving up there on Monday :))
Cheers Kev
Russell Coight:
FollowupID: 546297
Follow Up By: Member - Tour Boy (springsure- Wednesday, Jan 16, 2008 at 09:08
Bring your rain coat....eh
Dave
2015 Fortuner
FollowupID: 546298
Follow Up By: Member - JohnR (Vic)&Kath - Wednesday, Jan 16, 2008 at 22:50
Kev, you better fit muddies instead.
FollowupID: 546488
Follow Up By: Kev & Darkie - Thursday, Jan 17, 2008 at 06:54
John,
Plus a snorkel and floaties :))
Cheers Kev
Russell Coight:
FollowupID: 546505
Reply By: Member - Tour Boy (springsure- Wednesday, Jan 16, 2008 at 09:03
Hi mate,
I only run285's on my cruisers. The speedo reads 95kph when I'm doing 102kph.
You do lose a little bit of power due to the overgearing but not that noticeable.
They handle fine but that is BFG muds. Just keep in mind that a larger sidewall will flex a little more before the vehicle responds to the steering input (i'm talking about a fraction of a second).
But they get the diffs that little bit further out of the mud and that's a good thing.
I don't know how well they clear the guards on an IFS as I only use rigid front axle vehicles and no probs with a lift.
Dave
Dave
2015 Fortuner
AnswerID: 281892
Reply By: Kiwi & "Mahindra" - Wednesday, Jan 16, 2008 at 10:06
Same as the others....when doing 100kph really doing 107kph....
Slows car down a little but goes well other than that....we did over kill i think and had the cooper stt's in that size...over kill the bank account that for sure!
Laura
AnswerID: 281898
Reply By: Member - Doug T (FNQ) - Wednesday, Jan 16, 2008 at 10:26
Damon
I use 265s , even at that width you have to be on the ball if just one steer wheel hits a large puddle, be ready for instance correction.
AnswerID: 281902
Reply By: Damonw - Wednesday, Jan 16, 2008 at 10:45
I have the 265 Cooper ATR's at the moment but at 40 psi i find that there is a lot of bulge in the side walls I'm curious if the 285's will be better or worse( Toyota 16x8 alloys).
Damon.
AnswerID: 281906
Follow Up By: Member - Tour Boy (springsure- Wednesday, Jan 16, 2008 at 13:22
I run 35psi front and rear normally and when loaded with the camper on such as in my rig pic I run 42 all round.
Bulging has never been a problem. I've never staked a sidewall at those pressures.
On the last gulf trip for example my Father in Law suffered many more cuts to his Cooper muds than I did to the BFG's both at similar pressure although he had less weight (lighter camper and no kids crap).
Neither of us had punctures though.
Dave
Dave
2015 Fortuner
FollowupID: 546336
Reply By: tuck 01 - Wednesday, Jan 16, 2008 at 12:34
Damon
I have 285/75/16 Cooper STT's on my TD100. They are mounted on standard Toyota steel rims. I also have about 2" lift with OME suspension. I don't know if they would fit with standard suspension.
My speedo is 4% low ie speedo shows 100, I am doing 104.
Handling and general behaviour on the road is good, but I really have nothing to compare it to because I fitted 285/75/16 as soon as I bought the car. The first set were ST's, and they handled good too.
AnswerID: 281914
Reply By: Baz & Pud (Tassie) - Wednesday, Jan 16, 2008 at 13:44
We run Pro Comp 305 70 16 ATs on our 100series and the speedo is about 5kph out, 35 in front and 39 in rear due to (as Pud says, all that STUFF you have in the back) and have had these since vehicle was new and handles like a dream.
Baz
AnswerID: 281926
Reply By: peterjs - Wednesday, Jan 16, 2008 at 15:21
100 series GXL BFG 285/75/16 on Toyota ali wheels, 31psi front 32psi rear, good ride and had them on for just over a year now and no probs, have not done any real muddy stuff as yet, had the standard Dunlop grandtreck before and cant say notice much difference when driving, spedo out a bit, when showing 100 actual is 1004, hope this helps. Pete
AnswerID: 281943
Follow Up By: Gramps (NSW) - Wednesday, Jan 16, 2008 at 15:39
"cant say notice much difference when driving, spedo out a bit, when showing 100 actual is 1004"
Hahahahahaha it's all just a blur Pete. Is that when the afterburners kick in :)))))
FollowupID: 546359
Follow Up By: Bonz (Vic) - Wednesday, Jan 16, 2008 at 22:08
a bit? hahahah umm you couldn't do my next tax return for me could you??
FollowupID: 546475
Reply By: peterjs - Wednesday, Jan 16, 2008 at 16:27
Thanks Al, pleased you noticed, those tyres make a heap of difference ah 1004 klm and still going, ok just maybe I made a little boo boo, should that have been 104, have to get onto Mythbusters to sort this one out. Pete
AnswerID: 281955
Reply By: TD100 - Wednesday, Jan 16, 2008 at 18:45
My 285/75/16 Kuhmo a/ts make it 5km out and the 305/70/16 muddies are 4km out on my 100 series.i will put a speedo corrector on it,honestly!(been saying that for 4 years LOL)cheers Paul
AnswerID: 281976
Reply By: fozzy - Wednesday, Jan 16, 2008 at 20:45
have 285/75/16 bfg muds fitted to 04 td ifs with approx 45mm lift on front and approx 50mmlift on rear-when suspensiion fitted.
if you drive on these then change back to standard grandtrek rd tyres(16inch for 04 model) there is a huge difference in power take off.
suspension sageed a little on front each 12-18 months and on full lock there is rubbing of tyre up front(need to adjust front height again).
handle better in bush over obstacles and ruts etc in my opinion and woth the extra diameter. certainly at 100 i am doing more than 100.
certainly in my opinion and experience from a 100td ifs the extra height gained with 285/75/16 from standard size road tyres is worth it-not sure how much taller these are from your current tyres of 265/75/16.
fozzy
AnswerID: 281987
Reply By: Richard W (NSW) - Wednesday, Jan 16, 2008 at 20:53
Damon,
Another one who runs 285X75X16 BFG muds now with 70,000KM and still a bit to go. They have done a fair bit of outback touring. Speedo is out about 5% as others have said. I have the ATS 4X4 2" suspension mod. Even so I have had the rear tyres scrub the inside of the mudguards on full articulation. Handling is great both on and off road. I run 40psi on the blacktop.
AnswerID: 281988
Reply By: Member - Graham H (QLD) - Wednesday, Jan 16, 2008 at 21:26
Look here and you can work it out for yourself exactly
http://www.kouki.co.uk/Utilities/tyresizer.asp
http://www.miata.net/garage/tirecalc.html
http://www.dsm.org/tools/tiresize.htm
http://www.autisticcuckoo.net/tools/units/tyres.php
http://www.torquecars.com/tuning/alloy-wheels.php
http://www.rims-n-tires.com/rt_specs.jsp
This last one is really good as it allows you to compare rims and offsets etc so that u can try new combos for your wheels
AnswerID: 281993
Reply By: Damonw - Thursday, Jan 17, 2008 at 09:01
Thank you to every one for their replies.
Damon.
AnswerID: 282044
