air compressors
Submitted: Sunday, Jan 13, 2008 at 10:37
Member No 1
can I pls have the members opinion....
which is your prefered aircompressor (not neccessarily what you have)...also show a rating of between 1-10 where 1 is least wanted and 10 is prefered...if you must, you can include reasons why for other members to ponder
Reply By: Kev & Darkie - Sunday, Jan 13, 2008 at 10:41
12v or 240v
12v would be the new ARB one at an 8 out of 10 cause it is yet to be proved in long term use
I have the old ARB one in carry case and Darkie has a non working Blue tongue under his bonnet.
Cheers Kev
| Russell Coight:
281337
Reply By: David from David and Justine Olsen's 4WD Tag-Along - Sunday, Jan 13, 2008 at 10:46
EndlessAir or
home made, using an airconditioner compressor
10/10
281339
Follow Up By: Dave(NSW) - Sunday, Jan 13, 2008 at 11:16
I agree,I have an endlessAir 10/10 and a Big Red 4/10 which over heats & cuts out after pumping up only 3 tyres, Been like that since new.
Cheers Dave....
545701
Reply By: Keith_A (Qld) - Sunday, Jan 13, 2008 at 10:54
Blue tongue - wired into the back of GU Patrol (away from the engine heat) with airlines plumbed to front and back bumper.
Reason : 100% duty cycle. Rating? 8/10
But I used a supercrap one for several years before I saved for the bluetongue. Both pumped up the tyres, and neither makes the coffee.....................Keith.
281340
Reply By: Wayne (NSW) - Sunday, Jan 13, 2008 at 10:56
No 1,
This is another can of worms.
I think what you have to ask is when choosing a compressor is what is the toughest task that you want it to do.
If it only has to fill a small air tank to run diff-locks, just about any compressor will do that.
If you want a compressor that will reset a tubeless tyre on to a rim after a repair, that will reduce the number of compressors that are available.
I have found that the Big Red will reset a tubeless tyre on a rim and that is the one that I use. Having a compressor that will pump a tyre up in 10sec is not much use if you can't get the tyre set on the rim.
The only other compressor that I would look at is the End Less Air but that is limited as to where it can be fitted.
Wayne
281341
Reply By: Outnabout David (SA) - Sunday, Jan 13, 2008 at 11:44
They are all ordinary in my opinion. We all want one as fast as the
home or garage compressor and to re-
seat tyres. Haven't found one yet that will re-
seat tyres without drama. When I say that
mine will reseat tyres that have just been removed and still have memory to their shape. But very difficult to reseat them if you have 8" cruiser rims and the casing has ben lying down for ages.
Anyway I rate them all at 3/10. but believe the Bushranger max air to be a whole lot better than the old ARB one but then again I have a $100 bushranger copy that is the main one I use and that is just as good and been going stong for three years now.
281350
Reply By: Hoyks - Sunday, Jan 13, 2008 at 11:56
I have the old ARB one that was originally in a case. I would give it a 5/10, but since I got it I mounted it into the vehicle, installed a pressure switch and a small tap in the airline at the tyre end.
Now I would give it a 7 as it will reseat a tyre (just ;-) )by pressurising the small tank and the air line and releasing it all at once. Not real quick on inflation, but being able to trap the air in the line while moving around the vehicle helps. It has never cut out either, even after inflating 8 tyres in one hit.
Longevity is good too as I am the second owner and I know the 1st owner used it a bit and had it mounted under the bonnet.
281354
Follow Up By: Hoyks - Sunday, Jan 13, 2008 at 11:58
Oh, and I would prefer the new one based on my experence with this one, just for the inflation speed of the new unit.
545709
Reply By: _gmd_pps - Sunday, Jan 13, 2008 at 12:30
http://offroadrecovery.zoovy.com/c=5e5cnCGWcYWDSSslSypHSsykG/product/007-222/ExtremeAire_Magnum_6_CFM_Compressor.html
thats what I have on board. 10 out of 10 for me .. I have a stainless steel pressure tank (custom made) and drive all the air consumers on board. I drives my rattle gun and other air
tools easy and I can air up my 6 tyres from 25 to 60 psi without waiting for the compressor. I was looking at an endless air but it is too hard to fit it to my engine and the support was lacking completely.
It blows my 100 amp circuit breaker at times ( I have to upgrade to 150 or so, the cable I used is thick enough). Similar to endless air I run the engine when I air up but I guess even with the toy ones you eventually run the engine because most of the jap cars have no decent batteries.
I have a high idle switch so my alternators can even charge the batteries while I use the compressor. Usually it does not take more than 10 -15 minutes to air up all 6 tyres.
good luck
gmd
281361
Reply By: Member - Phil G (SA) - Sunday, Jan 13, 2008 at 16:23
I can't criticise my Blue Tongue III - its had a huge amount of work over 7+ years and still pumps as good as new. Give it 7/10 for quality and longevity. Its also got a fan, so it can pump continuously.
My backup/portable pump is the current model Terrain Tamer twin cylinder - It pumps at the same speed as the Blue Tongue and only cost $125. Give it 6/10 for value for money.
From others I've seen, you can't beat an air conditioner compressor for speed, but to install correctly is not possible on most vehicles.
For reseating difficult tubeless tyres I use a modified ARB deflater fitted with a length of hose and a tyre chuck - pump up another tyre, fit the deflater, remove the valve and 5 seconds later the first bead pops on.
281402
Reply By: Grungle - Sunday, Jan 13, 2008 at 17:18
Endless air 10/10, ARB 6/10, Bluetounge MKII 5/10 (have had all but got rid of the Bluetounge)
Most are slow but if you want to
seat beads then any compressor will do as long as you have an air tank to store some volume. I would recommend around 9L
Now once you get an Endlessair then you will wonder why you even considered any of the others. For an outlay of around $400 to build your own complete with tank, it works out to be around the same price or cheaper than the others. Also if the compressor dies, you can get another from a wreckers for $20-$40.
Not all engines can accomodate an Endlessair however. If interested in building one then I have detailed my experience
On my website.
David
281413
Reply By: Peter 2 - Sunday, Jan 13, 2008 at 17:41
I went with one of these, Big Pro 7 3.5 cfm on 12 volt, 5 cfm on 24 volt.
http://www.probag.com.au/components%201.html#compressors looks very similar to the one from off road recovery.
Works very
well, plumbed into a tank which then is connected to the Central Tyre Inflation System in the Humvee, can adjust tyre pressures on the go!!
Before that I had an early Blue tongue which never missed a beat, i was the second owner and both of us gave it lots of use.
281418
Reply By: Bonz (Vic) - Sunday, Jan 13, 2008 at 18:29
old ARB 5/10 - too slow but reliable
New max air 9/10
new new 50lt 16CFM 15/10
281424
Follow Up By: Member No 1- Sunday, Jan 13, 2008 at 20:55
15/10....Even MY SWMBO Cant Earn That accolade....it needs to be said cos no female is above 6/10....
And, I dont care if i have to get by without balls
545787
Follow Up By: Member No 1- Monday, Jan 14, 2008 at 09:14
what is it to get 15/10 anyway
545830
Follow Up By: Bonz (Vic) - Monday, Jan 14, 2008 at 17:44
Its just great thats what it is
545891
Follow Up By: Member No 1- Monday, Jan 14, 2008 at 18:23
your blow up doll?
545903
Follow Up By: Bonz (Vic) - Monday, Jan 14, 2008 at 18:28
I never refer to that as "It" and shush anyways, noooo I mean the 16CFM compressor I have
545905
Follow Up By: Member No 1- Monday, Jan 14, 2008 at 20:21
okay ...so we now know you have a secret ????-??-????
but why do you need a 16cfm comp to blow her up, whats wrong with your lips?...too salty?...and just waht make is this comp anyway
545932
Follow Up By: Bonz (Vic) - Monday, Jan 14, 2008 at 21:02
Its a scorpion, and theres only ever ONE reason to blow one of them things up
545946
Follow Up By: Member No 1- Tuesday, Jan 15, 2008 at 07:38
you have the Scorpion in your 4wd...
and your doll?
546013
Follow Up By: Bonz (Vic) - Tuesday, Jan 15, 2008 at 18:24
my doll...is named Marie and she puts up with a hell of a lot. Lucy almost has her at her wits end with suggestions for me to purchase. She is a doll and wonderful.
546130
Reply By: Member - bungarra (WA) - Sunday, Jan 13, 2008 at 21:13
9 / 10 Bluetongue
twin head as main compressor......7 / 10 blue tongue single head as back up (was originally my only compressor)..
basing my ratings on reliability first and volume supplied second...nothing is worth 10
was interested in an endless air but they cant even be bothered in answering an email enquiry about where to buy one..so have just purchased another
twin head blue tongue for second vehicle...
yes that gives me three blue tongues......a twin in each vehicle permantly mounted and the single head portable between either
281462
Reply By: Crackles - Sunday, Jan 13, 2008 at 21:33
ARB old..........2 out of 10
ARB new........7
Bluetounge.....4 to 5
TwinTounge...6
Warn Winch/compressor...9
Big Red..........3
ElCheapo cigarette plug types....minus 1 to minus 5 (not worth buying ;-)
MaxAir...........5
MaxAir Copy...4
Big Thumper..8
These rough ratings are of compressors I've used, seen running or heard 1st hand reports of. Priority was given to capacity, quality, price & duty cycle. The
pic is of my Big Thumper (sold under several names) was $320, about 4cfm, continuous duty but takes up a fair bit of room many wouldn't have under the bonnat.
281469
Reply By: KSV. - Monday, Jan 14, 2008 at 10:30
In garage I have cheap Chinese made “direct drive” 40L unit. Serve me ok, but not powerful enough to drive air
tools for long time plus some quality issues. 5/10
In car I have MaxAir from Bushranger 8/10 – dislike stupid curly hose, inconvenient case and very bad position for air filter. Performance-wise OK.
Also I have twin-piston compressor from Projecta that I plan to install permanently in my car altogether with receiver. Very fast, but incredibly bad quality. Still in stage of rebuilding. 2/10
Serg
281530
