nissan parts prices
Submitted: Wednesday, Jan 09, 2008 at 10:36
pepper2
Just got a quote from local nissan dealer for parts for clutch master cylinder for 3litre patrol.....$1130 for parts only crikey the parts would fit in your hand ...will try aftermarket....anyone know of an affordable option....?
Reply By: Member - Kiwi Kia - Wednesday, Jan 09, 2008 at 10:42
Can you indicate just what parts you got ?
280566
Follow Up By: pepper2 - Wednesday, Jan 09, 2008 at 10:54
At $1130 none, was advised it was a kit for the clutch master cylinder supplied by nissan
544814
Follow Up By: Member - Kiwi Kia - Wednesday, Jan 09, 2008 at 11:06
If it is just for a couple of piston seals sure it wasn't $11 and 30 cents :-))
544816
Follow Up By: Wetty - Wednesday, Jan 09, 2008 at 15:47
Hmmm. . . .
I got a quote for a steering wheel for a Bravo, $1293.00! After the bloke picked me up off the floor I called a few wreckers and now have one for $150.00. Now I know that a steering wheel is a pretty important part of the car but for that price it's no wonder you see clown steering their cars with spanners! LOL
Andrew
544869
Reply By: donks1 - Wednesday, Jan 09, 2008 at 11:22
ring another dealer
they have quoted the wrong part, common mistake with the catalouge
can't remember the part no. now. no longer with ni$$an
donks
280568
Reply By: pepper2 - Wednesday, Jan 09, 2008 at 12:40
Have now had a quote of $85 from local clutch and brake specialist to recondition the unit this is for parts and labour,I rang nissan back to double
check they advise the $1130 is for a new clutch master cylinder as nissan do not supply a parts kit to dealers or public sorry to have not been totally accurate earlier,thankyou for your replies
280580
Follow Up By: Member - Kiwi Kia - Wednesday, Jan 09, 2008 at 13:16
Would the local clutch & brake guys supply the o/h kit to you ? It's not a big deal to do it yourself. Also, do you have abs ? If so then you should ask here for some advice before you do it.
544829
Follow Up By: Member - Kiwi Kia - Wednesday, Jan 09, 2008 at 13:17
Should have also asked what are your brake problem symptoms ?
544830
Follow Up By: pepper2 - Wednesday, Jan 09, 2008 at 13:25
Clutch mastercylinder not brake,symtom is loss of vacuum if left standing o/night and slight loss of fluid over time
544832
Follow Up By: normo - Wednesday, Jan 09, 2008 at 15:25
I just rebuilt the clutch master cylinder on my triton for $10.95.
Using a PBR rebuild kit and cylinder honer, Took a little over an hour to complete.
544867
Reply By: Hoyks - Wednesday, Jan 09, 2008 at 14:18
Ni$$an are bad for prices. I just replaces a cross rod on my vehicle. Nissan wanted $480 for this part as it was vehicle specific. I got one after market for a Navara, the only difference was the Navara rod had a bracket attached for a steering damper and it was only $139.
Air flow meter was another, Nearly $900 genuine, $400 non genuine, even though it had "Nissan" and the Nissan part No moulded into the housing.
Injectors were going to leave me no change from over 2 grand ($1100 for No.1 and around $500 for 2-4) as I would have to buy the whole injector assembly. Got just the nozzles and needles replaced for around $300.
They certainly try to gouge you.
280603
Reply By: Member - MUZBRY (VIC) - Wednesday, Jan 09, 2008 at 14:37
Gday Pepper 2
I had a Brake master cylinder done not long back. Nissan wanted heaps more than Betta Brakes for the cylinder and the labour, so suggest a
check up with them. A new cylinder was fitted , not a rebuild.
280609
Reply By: Ozboc - Wednesday, Jan 09, 2008 at 16:12
You didn't specify where you were , if your in
Sydney Give PBR - ( Penrith brake and clutch) a call - those guys are pretty good and pretty cheap on after market stuff ....
Boc
280622
Reply By: Member - Mick O (VIC) - Wednesday, Jan 09, 2008 at 17:29
Try these guys. Give them an email at nizzbits@hotmail.com
Genuine parts at very good prices. You'll find a bit of
feedback about them on the
Nissan Patrol Forum.
Mick
280627
Follow Up By: pepper2 - Wednesday, Jan 09, 2008 at 18:19
thankyou will contact them
544907
Reply By: stefan P (Penrith NSW) - Wednesday, Jan 09, 2008 at 20:44
It has been mentioned before on here, quite a while ago....
Go and hire a patrol for the day and swap the part over ;)
Naughty hey!!!!! :)
Cheers Stefan
280670
