What other gauge
Submitted: Thursday, Jan 03, 2008 at 18:46
ThreadID: 53085 Views:2131 Replies:6 FollowUps:2
OK, thanks to this forum's advise I will be fitting EGT gauge, I was looking at pods to fit it in and thought a twin pod would look nice.
What other gauge do you think I should fit ??
Regards to all ...Tom
Reply By: StormyKnight - Thursday, Jan 03, 2008 at 19:06
Oil pressure gauge if your car only has a warning light....
Water Temp if you want a more accurate idea of whats going on....
Oil Temp Gauge?
Battery Charge - gives a better indication than just battery voltage
..... Cheers
Richard
AnswerID: 279589
Reply By: Member - Gomax (VIC) - Thursday, Jan 03, 2008 at 19:09
Boost guage if turbo'ed,
can recommend thermoguard products (forum sponsor as well...)
AnswerID: 279591
Reply By: Kev - Wynnum - Thursday, Jan 03, 2008 at 21:39
I've been looking at getting a pillar pod for two gauges. Is that what you are looking at and could you tell me where you have seen them
Thanks Kev
AnswerID: 279615
Follow Up By: Member - Mick O (VIC) - Friday, Jan 04, 2008 at 06:32
Try Autron.
Cheers Mick
FollowupID: 543830
Follow Up By: Member - John - Friday, Jan 04, 2008 at 06:57
Kev, the following ebay items will help you out, also there is sometimes a three gauge pillar pod on Ebay, that is what I have. 250202495530 or 140195276299 . Hope this helps. John
John and Jan
FollowupID: 543835
Reply By: Bonz (Vic) - Thursday, Jan 03, 2008 at 22:04
What about a mirror?
AnswerID: 279624
Reply By: Member - Mick O (VIC) - Friday, Jan 04, 2008 at 06:31
Try Autron. they make a great set of 52mm digital guages and a dual pillar pod. I have the dual battery monitor and a boost guage in the RH A pillar of the GU.
Mick
AnswerID: 279674
Reply By: Member - Graham H (QLD) - Friday, Jan 04, 2008 at 07:30
Am getting a Autometer Phantom EGT gauge from the states
Is a 5744M 0-900deg C full sweep costing $207 AU.
Can give u details if wanted.
Bought a pod on Ebay for $15 plus postage but u can get similar at Autobarn for $36.
Also have a Phantom OIl pressure to go in Mechanical $89 at Autobarn
AnswerID: 279683
