Computer Issue and Exploroz
Submitted: Wednesday, Jan 02, 2008 at 11:08
Member - Karl
Hi have an issue which is annoying me and I need help to fix it as I can't get access into this website.
The other week I was upgraded to Internet Explorer 7 and since then I try to access any postings in Exploroz two things either happen:
1. I cannot open a thread at all, or
2. If I do manage to open a thread the computer 'freezes'
with both issues if I go to 'Task Manager' it states that IE is not responding.
It seems to happen only with this site.
What can I do (in plain English please) to fix this problem.
Karl
P.S. I am making this post on the work computer.
Reply By: Mike Harding - Wednesday, Jan 02, 2008 at 11:19
Changer your web browser to Firefox?
Firefox
Mike Harding
279319
Follow Up By: Member - Ian H (NSW) - Wednesday, Jan 02, 2008 at 11:30
Since installing IE7 I have had similar troubles and considered changing to back Firefox. Now I will do it.
543475
Follow Up By: Member - MR 1927 (NSW) - Wednesday, Jan 02, 2008 at 11:35
Only way to go.
Steer clear of IE7.
543477
Reply By: Member - Troll 81 (QLD) - Wednesday, Jan 02, 2008 at 11:52
I have been using EI7 with no problems
check your secutiry settings
279327
Follow Up By: Member - John (Vic) - Wednesday, Jan 02, 2008 at 12:47
Yep what he said :-)
IE7 works great.
543487
Follow Up By: Mainey (wa) - Wednesday, Jan 02, 2008 at 17:48
Yep what they said :-)
IE7 works gr8
543532
Reply By: Sand Man (SA) - Wednesday, Jan 02, 2008 at 15:15
Failing other recommendations above, simply delete IE7.
As IE6 cannot be removed from Windows XP, deleting IE7 will revert to the previous version.
I didn't like the new interface of IE7 and deleted it.
279360
Follow Up By: Member - joc45 (WA) - Wednesday, Jan 02, 2008 at 17:33
Hope things have improved with the reversion procedure!
A few years back I reverted to a previous version of IE in Win98 (similar story; you can't completely remove IE in Win98).
Reverting to the earlier version of IE stuffed my Outlook program! No amount of reinstalling Outlook would fix it. Fortunately I was running Configsafe (like the Restore function in XP) and I managed to get it working again, no thanks to IE.
Bloody Microsoft!
Gerry
543528
Reply By: Steve63 - Wednesday, Jan 02, 2008 at 16:39
There have been a stack of patches for IE 7. If you have not applied them and want to keep IE7 that would be the place to start. I also vaugely remember there being a requirement to have SP2 installed to use IE7. The Windows Update Manager will do it for you if it is enabled. I hope you have broadband as the list of patches is quite long. It is a resource hog so if you have an older PC I would revert to IE6 or try Firefox. The other thing that may be happening is the popup blocker may be working.
Check for a yellow (usually) bar above the main panel of the browser. It will say something about a pop up being blocked. You can click on the bar and select allow popups. I have noticed in tha past that this can make the browser look like it has hung.
Personally I have given up on Windows and use Ubuntu and Firefox now. While not complication free my 667Mhz Pentium flies along.
Steve
279377
Follow Up By: Mike Harding - Wednesday, Jan 02, 2008 at 17:43
>and Firefox now.
Good point.
I resisted going Unix/Linux for a long time because some of my professional software required Windows (Schematic capture, PCB layout, SPICE etc) but I use these programmes less these days and should probably install a dual boot XP/Linux as 90% of my computer time is word processing, spread sheet, web browsing, e-mail etc and Linux with Open Office and Mozilla will do all of those and do them much more efficiently than Windows - especially Vista!
Mike Harding
PS. I first used Unix in 1983 on a 68000 CPU with a 45MB hard drive and 512K RAM - supported 8 users on TTYs :)
543530
Follow Up By: Steve63 - Thursday, Jan 03, 2008 at 10:43
I stuck with Windows for ages for similar issues. I now have set up dual boot winXP/Ubuntu 7.10 (Gutsy). I only use windows for video editing as the software is still better in winXP. I started out on a PDP 11 with 4 terminals. If you were first in you used to have to set the start address in binary (row of toggles on the front panel) and then turn a key to start it. I think it had a 10Mb disk and 64k of RAM. I remember having to put it into single user mode to use the Fortran compiler.
I know Ubuntu is much more economical with system resources. I would have no hope of running Vista (in fact I don't think it would even instal on my poor old system). I certainly could not run the Areo effects. Yet Gutsy runs all sorts of graphical effects (most better than the Areo effects) with no issues. I currently have a cube (four rotatable work spaces that appear on the face of a cube as you switch workspaces). The cube contains an animated set of gears inside the cube. It looks like an animated desktop. The comparison is scary really. Not only that installing Ubuntu includes Open Office, Gimp (bit like photo
shop), firefox and a raft of programming tools. Then there are the global repositories if what you want is not already installed. Updates are a breeze. I'm on my third version of Ubuntu. Each has been a leap forward. I don't know what they are planning for the next release in April but I can hardly wait.
Steve
543680
Reply By: DIO - Wednesday, Jan 02, 2008 at 17:16
IE7 works fine for me, always has. As suggested -
check your system Security Settings.
279396
Reply By: ExplorOz Team - David - Wednesday, Jan 02, 2008 at 18:53
Karl,
There are NO current issues with IE7 (I am using it now). I do most development using it then testing in Firefox and Opera. There is one open item that effects all Windows browsers and it is related to the version of Flash Player. If you are using an early version 9 player the browser will sometimes crash. It is not an ExplorOz problem however we use a bit of flash and hence this highlights an issue. Best bet is to ensure you have the latest flash player installed -
Flash Player Download
Other than that
check the size of your temp internet files cache - Tools - Internet Options - Browser History - Settings. Make sure the size is less than 250MB (around 200MB) seems to be the best.
Failing all this send me via email (david@exploroz.com) some more information and we can work it out.
279413
Follow Up By: ExplorOz Team - David - Wednesday, Jan 02, 2008 at 18:56
Forget the most important item - I hope you are not using Norton Internet security. Actually I will almost bet you are! If yes then disable it for a
test and try the site and see what happens. Let me know.....
The Norton product is not a very good product and causes all sorts of weird issues like this. If you have it whitelist the sites you like as it has a habbit of blocking critical code segments and breaking things.
543548
Follow Up By: Member - John (Vic) - Wednesday, Jan 02, 2008 at 19:05
David what is the effect of having to much cache enabled?
You suggest less is better??
543557
Follow Up By: ExplorOz Team - David - Wednesday, Jan 02, 2008 at 19:17
John,
I found out in many corporate environments that high cache values caused performance degradation due to the time it took for the cache lookups to complete. Some machines local processing of large caches takes ages (I have seen some more than 1/2 sec) hence several hundred image objects on a page will cause a cache lookup for every image so every 50 little 1KB images in a large cache using worst figures (from my testing) can take 25 seconds or more just to perform local cache lookup - then download if non existant or render from cache.
About 8 months ago MS changed the recommendation to less than 250MB (as shown on the IE settings page).
The other logic is that you should not really be carrying that much cache as most of it will be out of date anyway and require re-download so the extra lookup time is realy a waste. I setup 150 to 250MB on all my systems and on most of my client networks, sometimes even less down to 10-50MB on some networks. It all depends on the network however there is NO reason for a small business/
home machine to have a setting larger than 250MB.
IE6 used a percentage of disk space and when you upgrade to IE7 it keeps that figure. We must remember IE6 was released in the time of 20GB being a huge disk drive and settings of percent were 5-10% now 200GB is average and the caches have become way to large.
Anyway hope this helps and explains it a little.
543568
