Tilting bullbar aerial bracket
Submitted: Tuesday, Dec 04, 2007 at 20:55
Member - Mary W (VIC)
On a couple of occasions I have noticed vehicles with a tilting bracket on the bullbar for HF/long aerials allowing the aerial to be tilted backwards to allow access without the removal of said aerial to shed /carport etc.Does anyone know where one might obtain one?Many thanks,Mary
Reply By: Bob Y. - Qld - Tuesday, Dec 04, 2007 at 21:01
Mary,
Try any of the ship
chandler type
places, like Whitworths.
They stock marine bases that will tilt. Think some of the more resourceful members make their own, out of RHS, and a couple of bolts etc.
The GME/Electrophone website may have a base that would suit your needs too.
Hooroo,
Bob.
275020
Reply By: Willem - Tuesday, Dec 04, 2007 at 21:08
I had one made by a Member here by the name of JD, as I recall.
I could send a photo to you if you wish. Just contact me through my website below.
275021
Follow Up By: Member - Mary W (VIC) - Tuesday, Dec 04, 2007 at 21:32
Thanks Willem,/Will be in touch.
I enqired at local /
Mildura 4wd
places an all they had to say was if you find someone who makes them please let us know. Maybe JD is in business!
538688
Reply By: 96 GXL 80 series - Tuesday, Dec 04, 2007 at 21:11
Mary,
you can try a communications place or Tricky Dicky.
If it is a loose fit {In the swivel part} you can create static interference through your radio, you need a good connection.
275023
Reply By: padler - Wednesday, Dec 05, 2007 at 08:15
Hi Mary W. Try looking at www.pefabrication.com.au They are about $98 each and post is free.
275060
Follow Up By: Member - Mary W (VIC) - Wednesday, Dec 05, 2007 at 17:14
Thanks padler that looks like a nice bit of equipment,
Mary
538825
Reply By: Member - Mike DID - Thursday, Dec 06, 2007 at 13:09
If you want to communicate over less than 500km on HF, you will get as stronger signal if you tilt the aerial 45 degrees away from the vehicle.
275267
Follow Up By: Member - Mary W (VIC) - Thursday, Dec 06, 2007 at 15:03
Facinating!Some more information please,Mary
539001
Follow Up By: Member - Mike DID - Thursday, Dec 06, 2007 at 15:25
Local signals like UHF CB travel in a straight line, so you want the aerial vertical to send as much signal as possible out horizontally.
For HF signals to reach beyond 50km, they need to bounce off the F layer of the Ionosphere, which is 200 to 300 km high. For the bounced signal to land within 500km you need to send it up almost vertically.
A vertical antenna sends minimal signal vertically upwards. By tilting the whole antenna or just the whip top, you are sending more of your signal up vertically.
For HF signals to go more than 500km, a vertical antenna works best.
539006
