1hz thermostat experience
Submitted: Thursday, Oct 18, 2007 at 09:42
ThreadID: 50663 Views:12283 Replies:6 FollowUps:2
anyone had much to do with taking the thermostat out of a 1hz. does it help or cause more problems?. i would only take out the spring and seal and leave the housing for a bit of restriction. thanks.
Reply By: Member - Matthew C (WA) - Thursday, Oct 18, 2007 at 09:57
You may need to look at why you are thinking about taking it out more than what it will do when you take it out.
Hence:FIND & FIX THE PROBLEM
MAtt
AnswerID: 267150
Reply By: Member - Doug T (Qld) - Thursday, Oct 18, 2007 at 10:41
You have no option to but to leave the body of the Thermostat . It's not like a normal unit where you can completely remove it , if in an emergency situation you can take the guts of it out and replace the base because the base has the seal on it , Go and get 2 new one's from from Toyota ,Yes get two, you will need a spare one day, if you don't have a Thermostat it won't warm up in cold climate
AnswerID: 267161
Follow Up By: Middle Jeff - Thursday, Oct 18, 2007 at 19:38
Hi all
What Doug said, go to Toyota, it is the only thing that I get from them that I can get elsewhere. They are very different to every after market one and the only one that does job.
Have fun
Craig
FollowupID: 529634
Reply By: obee - Thursday, Oct 18, 2007 at 17:11
The thermostat is there to regulate the temp to the design operating temperature. Everything expands to the design tolerances and wear is minimised. Vehicle manufacturers try to build as cheap as is practical but leaving the thermostat aint. They would not put one in if it were not neccessary contrary to some urban myths like its ok to use tap water in the battery and the radiator.
Owen
AnswerID: 267211
Follow Up By: Member - Phillip S (WA) - Thursday, Oct 18, 2007 at 18:33
Good advice...SO LISTEN
FollowupID: 529624
Reply By: Tim Owen - Thursday, Oct 18, 2007 at 20:36
My 92 Troopy was running hot on my recent trip. Had new thermostat installed (genine toyota, part cost $39), now the temp sits 3 mm off the cold line, and moves very little, no matter how hard the engine is worked. I'm interested in why you wouldn't just replace it? I'm not very mechnically minded - so excuse if this is a dumb question.
AnswerID: 267245
Reply By: Member - Jiarna (NT) - Thursday, Oct 18, 2007 at 23:45
Hey if you take off the alternator, you'll get more power from the engine. But then again, maybe it's there for a reason?
In other words, just replace the thermostat - it's a lot cheaper than an engine.
Those who say something cannot be done should not interrupt the person doing it.
AnswerID: 267286
Reply By: Member - DOZER- Friday, Oct 19, 2007 at 00:02
Sam
dont touch it....Toyota diesels have a two stage thermistat, which closes off the circulate water through the block port when it opens up the circulate the coolant through the rad port, so removing guts will circulate water through the block unrestricted and you will overheat...it is a common problem with this motor to need a new fan coupling, they are on ebay cheap, i am guessing this is why you asked the question. One way to prove it is the viscous fan is to install an electric fan up front and switch it on when going up hill.
AnswerID: 267290
