80 Series wheel bearing socket
Submitted: Tuesday, Nov 06, 2001 at 01:00
Tony
I need a socket or tube spanner (54mm) to remove my front wheel bearings for service. The local
tools supplier in my town can't locate a 1/2 inch drive socket of that size or a tube spanner. He offered a 3/4 inch drive but the o/s diameter of the socket was too big to fit inside the recess. Can anyone tell me a brand name of a socket (1/2 inch drive) or tube spanner and a suppliers name and phone number to source this piece. I thought about making a tool but would prefer not to if at all possible. TIA Tony.
Reply By: David - Tuesday, Nov 06, 2001 at 01:00
Tony, try your local Toyota service centre, there probably guaranteed to have one, or try somewhere like Glenfords
tools or Hare @
Forbes or some of the earth moving repair centres, hope this helps, cheers, Dave.
1342
Reply By: Alex - Wednesday, Nov 07, 2001 at 01:00
Hi, I agree that making one isn't the ideal solution, but after similar lack-of-spanner-for-
hub-nuts on my landrover, I made one by bending a length of flat bar into a U shape and putting a bolt through it an inch from the end to tighten it on
the nut faces. I could then put a screwdriver or similar through the U to turn it (mostly they don't need to be that tight though). Hope this helps. Cheers, Alex
1353
Reply By: Gordon - Saturday, Nov 24, 2001 at 01:00
Tony, I have a GQ patrol,same problem, solved by using a piece of exhaust pipe (new) 2 1/2", 2 3/8"
what ever size suits. Approx. 6" long and shape one end to fit
the nut,the other end just drill a hole and use a screw driver. Works
well and costs bugger all.
1482
