JAYCO WESTPOINT HELP PLEASE
Submitted: Wednesday, Sep 26, 2007 at 21:11
ThreadID: 50054 Views:5450 Replies:3 FollowUps:3
My dad is looking at getting a caravan, has seen a Jayco Westpoint 18 foot 2000 model for sale, good condition(i think) $28-500 ONO.
Will be towed by a New Commodore.
Would it be suitable to tow on good dirts roads?
Anything else we should look for or know?
Thanks for your time and help.
Cheers Lyndon
Now is the only time you own
Decide now what you will,
Place faith not in tomorrow
Reply By: Jimbo Vic - Wednesday, Sep 26, 2007 at 21:25
That would be a Westport. Depends on its length, weight etc as to whether it would be OK behind a Commodore.
To me, 28.5 kilos for for a 7 year old Jayco sounds a bit tasty. At that wedge you would be expecting shower/toilet, R/C Aircon and some other nice gear and it to be in tip top nick.
Anything else you would like to know MM me or call me on 0411 874406 during the day. I've had a couple of Jayco's and they are great but this one sounds a little bit rich.
Jim.
AnswerID: 264071
Follow Up By: Member - lyndon K (SA) - Wednesday, Sep 26, 2007 at 21:28
Opps, westport!! sorry.
as said 18 foot, weight is 1580.
cheers lyndon
FollowupID: 525791
Follow Up By: Member - lyndon K (SA) - Wednesday, Sep 26, 2007 at 21:35
opps, and yes it has aircon
FollowupID: 525793
Follow Up By: Member - Graham H (QLD) - Wednesday, Sep 26, 2007 at 22:33
Is the weight u state the Tare or the ATM cos what I have seen of Westports on the Supertramp forum they are heavier than that when loaded. Look on the compliance plate in the boot.
Remember if the ATm is heavier than your cars towing limit you may not tow it legally even if its not fully loaded
Below is quote from a post of mine on that forum
I have been told on good authority that you cannot tow any trailer(van) which has a greater ATM than the car manufacturer recommends. Eg a car has a limit of 1500kg and your vans ATM is 1522. Strictly speaking thats illegal and as I found after adding a few bits and pieces the weight goes up and can put you over the ATM weight.if you still load the normal 300kg single axle or 400kg tandem allowance . You will probably find the same. EG Tare may not have included the Aircon or batteries etc or even the gas bottles. Mine turned up at 140 kg over tare dry so I can only put 260 kg of gear in it and stay within weight limit. Put the ball weight up 100kg as well. Also you have to check your car manual as when I had the Patrol I found after the van was hooked up I could hardly carry any extra luggage in it as it exceeded the load limit on it as you have to deduct your ball weight from the total load capacity. Just a few things from the mire of Transport rules that most people, me included dont think about or know about until sometimes its too late.
Easiest simile about weight is. Driver has a 5 ton truck licence Gets caught driving a 7 tonner with 3 ton on board. Says but Im not over my licence weight. Cop says maybe but truck can carry that but you cant drive it. Same as if van is stickered over car capacity and you leave water tanks dry to stay under . Sorry bud.
A bit of a rant but valid comment for the thread
FollowupID: 525808
Reply By: Member - nrb1748 (VIC) - Wednesday, Sep 26, 2007 at 21:34
18 footer behind a Commodore would be OK providing the tow bar and hitches are set up properly. If the Commodore does not already have an additional automatic transmission cooler, then one should be seriously considered. Better still, if the 'new' Commodore is yet to be purchased, the optional towing pack should be added.
nrb1748
AnswerID: 264075
Reply By: Member - Andrew W (VIC) - Thursday, Sep 27, 2007 at 08:07
The Westport is now 3 models old and was made in the days when Jayco were not renowned for their quality control. You could get a lot better make/model at that age for your $28,000.
I would guess the true value of the van (unseen) to be about $20- $22K's.
AnswerID: 264129
