1HZ squealing fanbelts again
Submitted: Tuesday, Sep 11, 2007 at 21:24
Harrow
OK put on a new matched pair genuine fanbelts.
After 1000 km starting to squeal again for 2-3 min after start cold motor
Tension still tight.
Had new alt pulley
Previous matched set had difficulty stoping squealing, had 1/2 teeth torn off after 15.000km/ 128 months
Can over tightening cause this
This problem is persistant
how has others cured their problem
Belt Dressing ?, Tighten/ loosen ?
Harrow
Reply By: A J - Tuesday, Sep 11, 2007 at 21:30
Harrow - have you ever tried rubbing a cake of dry soap on the belt.
A J
261624
Follow Up By: Harrow - Tuesday, Sep 11, 2007 at 21:46
Not yet
Hard to believe that modern technology needs an old remedy, feel there may be more of a root cause ie overtightining
523039
Reply By: Member - lyndon K (SA) - Tuesday, Sep 11, 2007 at 21:37
Sorry to hear of your troubles, did Toyota fit the belts?
Have had two 1hz"s and never had a problem.
Lyndon
261625
Reply By: padler - Tuesday, Sep 11, 2007 at 21:46
In the good old days we used to run the belts and rub chalk onto the belts, VERY carefully. A stick of school chalk is good.
261628
Reply By: Bilbo - Tuesday, Sep 11, 2007 at 21:52
Harrow,
I donlt know what kind of belt they are on a 1HZ. However if they are those ribbed or 'grooved' belts and fitted with a similarly riibbed pulley, I had the sanme problem with Suzuku Swift a few years back.
After trying just about everything, including a new
water pump and new alternator bearings, I finally figured out what it was.
The pulley had worn slightly and this was causing the 'grooves' in the belt to "bottom out" on the pulley grooves. This prevents the belt from sitting 'proud' in the grooves and it'll slip no matter how hard you tighten it, or no mater how much "Belt Grip" you spray on it.
I fixed
mine by first removing the belt and then starting the engine - with a hard, fine, flat file running against the top edges of pulley grooves. I could only run the engine for about 5 minutes as without the one belt, there's no
water pump. It is, howver an electric rad fan.
It wore out the file pretty quickly 'cos the pulley is very hard steel - harder than a file!! But it fixed it.
On a Suzi Swift this method was a lot easier 'n cheaper than taking the engnine out to remove the crankshaft pulley - a new pullley was "horrendous dollars" as
well! It's an 'east-west' engine on the Suzis.
Bilbo
261632
Reply By: Member - Phil G (SA) - Tuesday, Sep 11, 2007 at 22:05
Harrow,
Putting genuine twin belts on was a good start. They are not ribbed. I change
mine every 100,000k and theres no real
sign of wear.
I think they are still insufficiently tensioned. The span on those belts is pretty short, so theres not much deflection when they are correctly tensioned. I take it when the belts were off, that the alternator and
water pump rolled smoothly?
And I'll assume that you've ruled out noise from the air conditioner belt and idler pulley.
261635
Reply By: Olcoolone- Tuesday, Sep 11, 2007 at 23:08
All V belts are designed to be driven from the sides, as one of the post above mentioned about the belt bottoming out, if it bottoms out the belt will be over heated and start to glaze.
I would check all your pulleys to see if the belts are bottoming out and if they are replace the pulley or have ir remachined.
Check also for belt alignment, a belt should have no more then 2mm over a 300mm span.
Using a file is not a good idea because it it very hard to get the right angle of the V.
One other thing is to check the cross section size of the belt, automotive belts come in a range of cross sections 9A, 10A, 11A, 13A, and 15A before you start going into B,C and Poly Groove belts.
Always make sure you use a belt designed for automotive applications....these belt are designed more for high speed.
Regards Richard
261646
Reply By: 2-GEE,s - Tuesday, Sep 11, 2007 at 23:22
Dry soaps the go, works every time.
261650
Reply By: TEQ105 - Wednesday, Sep 12, 2007 at 10:47
New belts usually need a retension after 1000kms, it sounds like they need a nip up, this fixes
mine when my 1HZ belts squeal, same with the air con belt when you turn it on for the first time after winter
261687
Reply By: MEMBER - Darian (SA) - Wednesday, Sep 12, 2007 at 18:04
If your pulley is worn, maybe consider a belt with a slightly wider profile ? .......in the same length..... might be available.
261742
Reply By: Member - Phil G (SA) - Wednesday, Sep 12, 2007 at 18:15
Harrow,
You have a bunch of suggestions for slipping belts and a bunch for belts that are not slipping, but making noise. Hitting a slipping belt with the soap trick will only make it worse.
So what do you think? Is the belt slipping or not?
Usually if it makes noise at startup only, its slipping, and needs tightening.
261746
Follow Up By: Member - Hughesy (NSW) - Thursday, Sep 13, 2007 at 18:04
Your dead right Phil. If it only squeals for the first few minutes after start up - its definately slipping while the viscous hub is locked. After a few minutes the hub free wheels and the squeeling stops. I'd retension.
Haven't got the toyota book on me but someone should be able to give you the deflection distances for the belts
Harrow.
523383
Reply By:- Thursday, Sep 13, 2007 at 10:37
Excellent thread! I have same problem and now I have food for thinking. Thanks everyone!
261860
Reply By: Harrow - Thursday, Sep 13, 2007 at 21:13
Thanks Guys
Sprayed on belt grip , lasted 24 hours
Given that 1000 km since install, tried retension , keeping in mind short deflection distance (still cautious about overtightening)
Squealing gone
So looks like you haveto be aggressive on belt tension
Bruce
261959
