tyre pressure over corrugations
Submitted: Tuesday, Jul 10, 2007 at 15:24
dangerous damian
travelling around in an 83 troopy converted into a camper so carrying a bit of weight in the back. gear bounces around a bit and the old girl's developed a fair few rattles over the years. just about to hit some corrugations in the next part of the trek and wondering if lowering tyre pressures helps with the shakes and comfort over the rougher terrain and if so do they need to be re-inflated before hitting the tarmac again. any help on the issue would be great!
damian
Reply By: Andrew from Vivid Adventures - Tuesday, Jul 10, 2007 at 15:34
Yes and yes, but you need to reduce your speed to match... how much will depend on what tyres and what load.
251712
Follow Up By: Blaze - Wednesday, Jul 11, 2007 at 00:33
I totally agree with Andrew.... Depends a bit what load and tyre style and brand... If they Radials and load is the normal heavy 4X4 load, I would recomend around 38psi for black top and 26front and 28rear for rough stuff....
512886
Reply By: jeffwa - Tuesday, Jul 10, 2007 at 18:23
Absolutally. We carry a fair bit of weight around with us and generally have the tyres at 42psi on the highway. I drop them down to 29-30psi for corrugations, even lower if they are really nasty and it's like someone has just graded the road. Never had a problem doing it, I use the stauns to drop the tyres and have an air compressor and air tank to pump them back up again after.
251738
Reply By: Voxson - Tuesday, Jul 10, 2007 at 19:34
I always drop my tyres to 25psi for any dirt roads inc corros...
If we get to blacktop and it is only a 100kms or 200kms till out next stretch of dirt i just motor along doing 60-70kmh...
That info is for most northern dirt roads,,, having said that there are plenty that i would keep my pressures at 38psi...
A dirt road with minimal rocks and stones with few corros i wouldnt even bother letting them down..
People come to grief by not slowing down for dips on dirt roads and the rocks at the bottom of those do the damage at speed..
251763
Follow Up By: Blaze - Wednesday, Jul 11, 2007 at 00:38
So Vox you are the a-hole sitting on 65k's that I couldn't pass with my van in tow the other day between
Big Desert and Hattah LOL,
Only jokin mate it was a Cockie in his 75 series .....
512888
Follow Up By: Voxson - Wednesday, Jul 11, 2007 at 13:34
Yeah it was me...
On the Calder Hwy...
I remember you now...
I was actually speeding up every time you started to line me up.. lol...
512953
Reply By: Member - Phil G (SA) - Tuesday, Jul 10, 2007 at 19:43
For any dirt road, I drop to about 25-27psi.
On bad corrugations I go lower. I'd rather risk tyre damage than damage the vehicle.
How low is too low??? I did the Anne Beadell Hwy once at 18psi in a 49 degree heatwave, and a couple of months later found the odd bulge on the inside of the tyres from delamination. So I guess that was too low. These days I run low 20's on corrugations, and usually travel at up to 50kph.
251768
Reply By: Batt's - Tuesday, Jul 10, 2007 at 20:45
The type of shockies you run makes a big difference medium shockies seem to be a good allrounder.
251785
Reply By: Steve from Top End Explorer Tours - Tuesday, Jul 10, 2007 at 23:26
I currently run 4 trucks 1 Troopy and 3 100 series daily, over 100 ks of the very corrugated Jim Jim road, I run 9 persons in the troopy, 7 in the 100 series, I run my tyres at 40 front 42 rear and have done so for years.
I have no intention of changing this method any time soon, as I have worn out 11 sets of tyres at aprox 55000 ks with no problems.
Cheers steve.
251820
Follow Up By: Richard Kovac - Wednesday, Jul 11, 2007 at 22:01
What sort of tyres Steve?
skinnies on splits or widies on steel?
Richard
513042
Reply By: Steve from Top End Explorer Tours - Wednesday, Jul 11, 2007 at 22:51
Bridgestone A/T duellers 265/75/16 693s Ozi made.
Never leave
home without them.
Cheers Steve.
252000
