navarra tyre replacement
Submitted: Monday, Jun 04, 2007 at 22:05
ThreadID: 46282 Views:2149 Replies:2 FollowUps:1
Just replaced D40 Navara tyres with BFG AT's 265x75xR16. They do fit but is is close (doubt it would take 275's - and no way 285's).
It has changed the vehicles handling completely - it now 'swims ' on the freeway, with what seems like half a second response to turning the wheel, before the side wall flex catches up. However against that the ride has softened and it takes bumps better and there is less of the rear wheel skip on corrugations.
Off road it is a different vehicle - now seems to want to go anywhere , specially in the wet, and the 25 mm lift hasn't done any harm either.
Had BFG AT's before (on a Jackaroo) but I am amazed at the difference on the D40 - not sure yet if that is all positive or a bit negative!
Reply By: Wayne-o (Pilbara WA) - Tuesday, Jun 05, 2007 at 00:54
What tyre pressures you runnin.
BFG's need to run around 40-45 psi, something the dealer wont tell ya.
hope this helps
Wayne-o
AnswerID: 244797
Reply By: Member - warren B (QLD) - Tuesday, Jun 05, 2007 at 09:43
gday andrew. ive just put the same tyres on my d40 and at the same time put a 2inch lift under it, all tjm gear plus air bags its now 100% better on road great off rides nice and tight, cant recomend getting rid of original shocks springs ect enough.
AnswerID: 244837
Follow Up By: Member - Andrew W (VIC) - Tuesday, Jun 05, 2007 at 10:59
The lift kit is next on the list but at $2000 it will have to wait a while! Are you running the BFG's at 40 - 45 as above?
FollowupID: 505941
